Basically it won't come on :D
Got hot water OK but when I turn up the Stat the 3 or 2 way valve is not opening. If I manually open it the pump kicks in and the rads get hot. I've been here before all too often and a replacement motor for the valve sorts it as a rule. Rather than pay a plumber to do it I'll go buy a motor and do it myself but I notice the motor has 5 wires connected but an older one still laying up in the loft has only 4 wires why is this as they have both worked! Also is it likely the motor has failed or do I need to replace the whole head?
