What heater??
  • What heater??
    Need to buy a heater capable of heating my garage, no my workshop as it's now known ;)
    Extensive works but it's nearing completion :D
    Got a little fan heater which is ok at the moment but I know that soon it won't cope so ideally looking for a gas heater but open to suggestions as se of you must have some good ones.
    It's a standard size garage and all the gaps etc are in the process of being sealed so this will help loads.
    Any ideas? Where to buy etc??
    :cheers2:
    a super sir gas heater is good Ben but it still needs ventilation m8
    adieuk
    x7 eddie gold stars!
    www.eaglerc.co.uk
    dx7, phoenix sim
      Not ideal really as I don't want to gas myself in there :D
        As said Gas ok, but needs ventilation unless you buy a balanced flue one, and put the flue through the wall.
        My garage is a double, and I use an electric fan heater, but it is about 450-500mm long and 100mm high! Still 3 Kw, but can get very warm in there! I do also use a de-humidifier all year round to stop rust forming! Works a treat. Another thing to do if you have the head room is to buy 1-2inch of builders celertex or similar and then 22mm chipboard/Stirling board to walk on. A warm floor is fantastic, and will keep you really warm.
        Henseleit TDR V-Bar x2
        SAB Goblin 700 V-Bar
        T-Rex 700e DFC V-Bar
        Synergy N7 V-Bar OS105 HZ-R
        Synergy E7se V-Bar
        Synergy N5c FBL V-Bar
        Gaui NX7 V-Bar YS91 Tareq SRX
        T-Rex 550 E FBL V-Bar
        Gaui NX4 V-Bar
          a electric greenhouse heater is good to they pump the heat out
          adieuk
          www.eaglerc.co.uk
          dx7, phoenix sim
            I have an aircon unit that is capable of heat too, they arent that dear anymore...
              extend the central heating with a three way valve to the most important room in the house... !
              Steve
              Steve...
              Outrage RC Field Rep
                run your lipos till they get hot
                mark
                3x700s none mine
                  I have some balanced flu heaters you can have if you want them. Ill post a pic Tommorrow if you like. Sort out collection and thier yours.
                  Quite compact units.
                    Or do what Callum did at the RCHA Flyin.
                    In his little one man tent at about 2 in the morning he was cold so he decided to fire up his 600 nitro for a few minutes so that he could warm his hands on the muffler! Nearly choked to death, greasy nitro lining to the tent, baled out and got even colder! Lol
                    __________________________________________
                    Dave
                    T-Rex 600E - BeastX -
                    T-Rex 550E - BeastX
                    T-Rex 450 PRO - BeastX -
                    T-Rex 250 - BeastX -
                    DX8
                      we use infra red heaters at work and they chuck out loads of heat.
                      Trex 550e dfc :-)
                      t-rex 450s x2 /Raptor 50
                      kyosho spree small plank
                      bogey combat plank x2 woop
                      http://www.cuffleymfc.co.uk
                        I have an oil filled electric convection heater with a thermostat
                        This coming time of year I leave it in 24/7 on a low setting just to keep the damp out, when I want to work in there I use a small calor gas heater and that just tops up the heat.
                        TDR (in progress)
                        SAB Goblin 700
                        Vibe 90SG Vibe 500E
                        Kalt Baron30
                          Cheers all
                          Any links?
                            tubular heaters connected to a thermostat, low power consumption and will keep the room at a constant temperature, wall mount low level, use a few around the room and will keep it damp free too.
                            [url=http://www.google.co.uk/products/catalog?q=tubular+heaters&oe=utf-8&client=firefox-a&rlz=1R1GGGL_en___GB356&um=1&ie=UTF-8&cid=1887179849427213590&ei=BYuhTJD_MZKZOJ_k6asE&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDAQ8wIwAg#]Dimplex 120W Wall or Floor Mounted Tubular Heater 710mm Long[/url]
                            [url=http://www.alertelectrical.com/cat/111/multi-purpose-heaters]Multi Purpose Heaters - Versatile Heaters for Different Purposes[/url]
                            just random links from the web for ideas, would try a local electrical wholesaler or wickes / b&q if interested.
                            cheers.
                            Steve.
                            Trex 700 LE
                            Trex 600 LE
                            Trex 450 Pro
                            DSX 9
                            www.midlandhelicopterclub.org.uk
                              Ben
                              I have got one of these and there fine, just plug it in with one of them plug timers so u can turn it off when u know u r not going to be there and time it to come on a few times a day just to maintain temp inside.
                              [url=http://www.argos.co.uk/static/Product/partNumber/4150633/c_1/1%7Ccategory_root%7CHome+and+furniture%7C14417894/c_2/3%7C14417894%7CHeaters+and+radiators%7C14417957/c_3/4%7Ccat_14417957%7COil+filled+radiators%7C14417968.htm]Buy Dimplex 2kW Oil Filled Radiator. at Argos.co.uk - Your Online Shop for .[/url]
                              This one is on special.
                              [url=http://www.screwfix.com/prods/22311/Heating-Cooling/Electric-Heating/2000W-Portable-Oil-Filled-Convector-Heater;jsessionid=ARSWDRVBDFFD0CSTHZOSFFI]2000W Portable Oil Filled Convector Heater - Screwfix.com, Where the Trade Buys[/url]
                              Lee
                              Crashing is in my blood, were can I get a transfusion
                              You can never have to many batts
                              Flasher 500
                              Trex 450v2
                              Dx6i
                              Purfleet Model Helicopter Club member
