Catalytic Flueless Wall Heaters
  • Catalytic Flueless Wall Heaters
    Winter is almost on us so time to think about heaters /keeping warm/Damart etc :-(
    What's your experience of heaters type in the title?
    [URL="http://www.fireplacemegastore.co.uk/catalytic-flueless-gas-fires/eko-fires-5070-flueless-gas-fire"]Eko Fires 5070 Flueless Catalytic Gas Fire Best Price in the UK[/URL]
    This price seems to be too good to be true for a 2.6Kw gas heater. Brochure looks good for impressing a sale.
    Killer question : If you had them, would you buy it again?:confused::confused:
    Cheers :cheers2:
    I didn't even know that kind of thing existed ! A gas fire without a chimney ? Cool. I would have a Carbon monoxide sensor myself (just in case).
    Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
    Align T-rex 700e, Align 610 x3, 3g, Spartan 760,Align 650, Bec pro, Castle Creations HV 110A.
      [quote=Sieze2;538561]I didn't even know that kind of thing existed ! A gas fire without a chimney ? Cool. [B][COLOR=Blue]I would have a Carbon monoxide sensor [/COLOR][COLOR=Blue]myself[/COLOR][/B] (just in case).[/quote]
      Such fires are fitted with oxygen sensors or else elth & safety police (:ack2:) will get you.
        [quote=Hangar-7;538566]Such fires are fitted with oxygen sensors or else elth & safety police (:ack2:) will get you.[/quote]
        Sure, I read that, but "belt and braces" and all that !
          Screwfix have a offer on a fire like that one [url=http://www.screwfix.com/prods/82880&cm_mmc=Campaign-_-E10W35-_-A-_-PianoGasFire?source=aw#]Focal Point Piano Black Glass Flueless Gas Fire - Screwfix.com, Where the Trade Buys[/url]
          :cheers2:
          Gaza07
          Trex 500esp 6s Beast-X V3
          Trex 600esp 12s Beast-X V3
          A few Multi Rotors
            I am a gas engineer, so ask away!
            The only problem with a flueless fire is that you HAVE to have a 100cm sq open air vent in the same room ( so a gale wind blows in!!) and another heat source (ie Rad) as those fires are not designed for continiouse use. To be honest, not alot of heat comes off them. They all have catalytic converters in them, and best to have them serviced every year, if for nothing else but to check the parts per mill of carbon monoxide given off. Max is 25 per mill, but most give 10-15 parts per million.
            Henseleit TDR V-Bar x2
            SAB Goblin 700 V-Bar
            T-Rex 700e DFC V-Bar
            Synergy N7 V-Bar OS105 HZ-R
            Synergy E7se V-Bar
            Synergy N5c FBL V-Bar
            Gaui NX7 V-Bar YS91 Tareq SRX
            T-Rex 550 E FBL V-Bar
            Gaui NX4 V-Bar
              Wouldnt go near it with a barge pole, reckon as Rctintin pionts out the installation regs mean it would actually make the room colder most of the time and therefore cost even more to heat.
              Pico z * 2 (I know they arent 'proper' helis but they are to blame)
              MCX - Got bored after a fairly short time.
              MSR * 2 (my current favourite)
              SR -as yet unflown
              Ewan
                RCHA forum really amazes me - ask a question and you get some valuable and honest advice and it does not have to heli related!!!
                So thanks[COLOR=Blue][B] [I]Rob & Ewan[/I][/B][/COLOR] for your excellent advice - I've been thinking along the same line. Added to your answers, I also wonder where CO2 and H2O are going to end up??
                So it's going to be a balanced flue heater (which I already have in the room) but barely 18 months old and have become very temperamental regarding ignition. It's a Baxi "Comfort" (:ack2:), stopped making it so no spares available. Apparently this is a design fault.....
                @ Rob, do I buy another Baxi or shall I switch to any one of these Balanced flue model :
                [URL="http://www.fireplacemegastore.co.uk/no-chimney-balanced-flue-gas-fires--4-32"]No Chimney Balanced Flue Gas Fires Stoves Hole in the Wall Fires - pg 4[/URL]
                or any other brand you could recommend would be much appreciated.
                Cheers :cheers2:
                  Pritty much any fire that is 'balanced flue' ( for those who don't know, that means the flue has 2 pipes one inside the other (normally). The inner being the exhaust and the outer being the air consumed by the flames) will be fine. I would recommend Flavel, Stoves and Valor as the 'better' brands. Baxi are living off their reputation of back boilers, but I would never ever sell a modern boiler to a customer made by them! (I don't want the comebacks when it goes wrong!!)(allegedly!!):)
                  Have a look at Plumbcenter for fires, but not prices! Look on net for good price!
                  Synergy E7se V-Bar
                  Gaui NX4 V-Bar
                    Thanks Rob for your valuable suggestion - search for Wall heater resumes at 20:00 hrs. [IMG]http://www.rcheliaddict.co.uk/testvb/images/icons/icon10.gif[/IMG]
                    Cheers :cheers2:
