butane propane
  • butane propane
    does any 1 know if i can use butane on my bbq inplace of propane:cheers2:
    Gazza
    Gaui x7 lush
    Gobbalin 500
    ALL ON SPEKKY GEAR
    Blade 130x2
    nano
    Give it a go Gaz :D
      u would say that u git, just to see me with no eye brows
      Gaui x7 lush
      Gobbalin 500
      ALL ON SPEKKY GEAR
      Blade 130x2
      nano
        Most BBQ's are fine on butane or propane. Propane burns hotter, butane burns cleaner.
        As long as you have the correct regulator for the bottle you should be fine.
        Andy
        This week I have been flying my Trex 600 FBL
        Heli mood =
        Humble owner of an EGS
        Member of a club
          [quote=Heliheaven;495730]Most BBQ's are fine on butane or propane. Propane burns hotter, butane burns cleaner.
          As long as you have the correct regulator for the bottle you should be fine.[/quote]
          Gaz is using the check valve off his YS so he should be fine :D
            nice 1 healiheaven, think i will have a go
            Gaui x7 lush
            Gobbalin 500
            ALL ON SPEKKY GEAR
            Blade 130x2
            nano
              [quote=Tom Burgess;495737]Gaz is using the check valve off his YS so he should be fine :D[/quote]
              also using the reg, seems to cook quick now hee hee
              Gaui x7 lush
              Gobbalin 500
              ALL ON SPEKKY GEAR
              Blade 130x2
              nano
