Was trying this out today as its nice and calm and no rain yippee :)
anyways did not do to bad, and found it easier when the batt pack was fresh as the power helped.
First thing I was getting use to was using the rudder as a elevator, but this was not to bad, only thing I had to do was give a little test what side I was going to throw the aircraft on to make sure I put the rudder in the correct direction.
Once I was use to that worked on getting it under control in the strait line and this was getting use to using the elevators as a rudder, found it a little tricky at the start but soon was doing quite a tidy knife edge, needs a little more practice but coming on nice.
Also had a go flying the SU26 with full expo on LMFA that thing can spin about 4 times in about 3 foot. But will change it a little as there is to much on full and the aircraft can do 1 full turn in about half a second.
