Micro hawker hurricane!
  • Micro hawker hurricane!
    Well, i said i was going to do a super cub kit but finished part of it then the wings broke! So i have a 14.5 in span guillows hurricane. I AM going to put in a brushless motor and 2 4.5g servos. I am only going to have aielerons, elevator and throttle as its not worth rudder so i save weight without rudder control rod, servo ect. Follow this thread if you want to see the build. view the pictures to see how im getting on!
    ENJOY!!!!
    P.S. I personally think the hurricane was the best WWII british fighter as without the hurricane, we wouldnt have won the battle of britan. Hurricanes are so under rated, they still have a RR Merlin so BEST SOUND IN THE WORLD!!!
    Thanks,
    Jake!
    Trex 600E EFL PRO -Spirit FBL
    Goblin 500 competition -Spirit FBL
    good effort jake, i look forward to seeing how you get on, i quite fancied doing something similar but i've ended up building a bigger plan instead, just keep an eye on weight with the radio gear installed and i'm sure you'll do fine :)
      all together the wood without covering weighs in at just under 30g, i aim for 70 g max with radio, motor servos ect. Its not an easy build!
      Thanks,
      Jake!
        just put in the main strengthener across the formers! easy!
        Thanks,
        Jake!
          [quote=jakegazzard;426608]
          P.S. I personally think the hurricane was the best WWII british fighter as without the hurricane, we wouldnt have won the battle of britan. Hurricanes are so under rated, they still have a RR Merlin so BEST SOUND IN THE WORLD!!![/quote]
          I do to, it is truly under rated. Ok not as fast or agile but being fabric covered frame it would take more of a beating and keep flying. Historic flying at Duxford were one of my customers a long time back, and I was lucky enough to get to sit it both and the Hurricane just had a feeling about it that brought home what these guys when through and did for us. Having a Grandfather who was a pilot during WWII just writing this wells me up.
          Cheers Adam
          Volatilis vacuus alai
          Owner of an "Evil Gold Star"
            The spitfire is well being fully metal but as you said the hurricane is a wooden frame, partly aluminium covered but mostly fabric. Much Easier to repair and a cheaper construction than the spit! Also like iv said, the powerhouse is magnificent! In my eyes the greatest engine ever built! Only problem was that the merlin had a float type carbouretta and once inverted, the engine starved of fuel. I LOVE British aviation!
            Thanks,
            Jake!
              all formers are up, all stringers are in plac e on the left side, now the right. Ailerons... well these are a wee bit harder than i expected! almost finished the right hand side aileron, a lot bigger than scale sadly but they would have been far too small! i will upload pics later.
              Thanks,
              Jake!
