A bit of help?
  • A bit of help?
    Trying to fix my Boiler and I'm pretty certain the PCB needs some new Capacitors, problem is I have Maplin part no's but they are out of stock of one of them and have been for days. I need the following:-
    22uF 63V Radial case (Maplin VH28F)
    4.7uF 63V Radial case (Maplin VH19V)
    22 uF 63V Axial case (Maplin AT04E)
    I've tried RS but they are in packs of 5 and I just can't see the point of buying 5 of each.
    Does anyone know of another source or even has said items kicking around for a few quid via PP? I know a few of you are employed or dabble in the electronics side of things ;)
    Cheers :D
    Phil
    might have some kicking about - will look later. What makes you think the caps are faulty?
      Try [url=http://uk.farnell.com/]Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.[/url]
      Thanks Russell
      proud owner of 1 EGS
        [quote=Gav;426430]might have some kicking about - will look later. What makes you think the caps are faulty?[/quote]
        Thanks :D
        It's a common fault apparently!
        I can get a new PCB but with prices from around £25 up to £140 , second hand to new I thought I'd try fixing it first for a couple of quid ;)
        Phil
          [quote=russell;426432]Try [url=http://uk.farnell.com/]Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.[/url]
          Thanks Russell[/quote]
          I will have a look there after my dinner :D
          Phil
