streaming media from laptop to xbox 360! how?
  • streaming media from laptop to xbox 360! how?
    does anybody on here stream videos/music etc from there laptop to there 360? does the xbox have to be connected to 360 via a ethernet cable ?and how do you set it up through windows media player?:confused:
    Yup, connect it using some cat5e cable and use the share options in WMP.
    x 3
      [quote=sacko;404652]Yup, connect it using some cat5e cable and use the share options in WMP.[/quote]
      whats a cat5e cable? can i connect both using a ethernet cable? just wanna get some photos across and vids! if i wanna get videos from laptop to the 360 can i put them on once and store or does it have to stream from the laptop everytime??
        Ethernet cable is Cat5e. There are loads of guides online, even on the MS website, ill have a look for it.
        x 3
          [url=http://www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/mp11/xbox360towmp11xp_stepbystep.aspx]Stream Music from Your Computer to Xbox 360[/url]
          [url=http://hubpages.com/hub/Streaming-Music-from-PC-to-360]Streaming Music from PC to 360[/url]
          x 3
            If you are connecting the laptop direct to the xbox you will need a crossover cable NOT a patch cable.
            If you are connecting via a router/switch then a patch cable is needed.
            www.lincsheli.com
              That was only on the Xbox, not the 360. Im using Cat5e on mine fine.
              x 3
                Thanks for the help sacko! sorted! i can now view photos that are on the laptop but how do i see the downloaded videos that i have on my laptop?? do i have to change folder name or something?
