im going to try and setup my f-27c stryker. its a delta wing type plane and im going to have to setup some aileron and elevator mixing in my ff7 tx as the plane only uses 2 servos to fly which is probably the same as a zagi flying wing etc.
normally ch1 is aileron and ch2 is elevator
will it matter which wing servo plugs into which channel and is there anything else i should know about this type of plane/setup
matty
matty
