Any computer experts on here
  • Any computer experts on here
    I have a laptop that is obviously not very well, when I try to turn it on the screen dosnt come on, it does occasionally after about 50 attempts but is very hit n miss, any ideas what's happened please, I want to make some adjustments to my vbar :(
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    not an expert but have you left it on charge a wile before you try and start it . My vaio wil not start if its flat must take too much power from the charger. also take the battery out and hold down the power button for 30 secs then try again ..
    iCharger 4010 , PL8 charger,
      It'll be the little power controller for the screen called an inverter. Is it a Dell?
      PS. Put a bright torch on it and see if anything is there. If not the screen may be on the blink or it may be the motherboard.
        Yeh tried all them tricks still no joy, cheers anyway
        Trex 500l Dominator
        Trex 450l Dominator
        Mcpx bl
        Pheonix sim
        dx8
          [QUOTE=helijohn;1144616]It'll be the little power controller for the screen called an inverter. Is it a Dell?[/QUOTE]
          No its a Lenovo bout 3-4 years old
          Trex 500l Dominator
          Trex 450l Dominator
          Mcpx bl
          Pheonix sim
          dx8
            If you dont get anything on the screen at all then it's unlikely to be software related, it's almost certainly hardware. Hard to say exactly what, the fact that occasionally it starts reminds me of the common problems PC's and many electronic devices used to have in epidemic proportions a few years back, that bad electrolytic capacitors. The symptom if it is capacitors is difficulty in starting up, needing many attempts, but once it gets going it's ok, but it gets gradually worse until it wont start at all.
            If it is capacitors you can usually see the problem as the tops of the caps swell outward and might leak a red/brown gunk. You would have to open up the case to be able to see the motherboard to see the caps.
            But potentially it could be many things...
              Have you tried plugging the laptop into a monitor or TV via the VGA or DVi output from the laptop? From here you can determine if it's hardware or software related. If youget an output I'd reinstall your gfx card drivers if you have one. Depending how old your laptop is the CPU could run integrated gfx if.
              Start>control panel>system & security>system
              Copy & paste the specs in nest post
              Thunder Tiger Raptor E820 - KDE 700XF 395 - YEP 180A - Futaba HV 272/274SV - Bavarian Demon 3SX - SAB 800mm - 6.6V LiFE
              Blade 450X - Stock AR7200 Beast X
              DX8 - AR8000 + Sat & TM1000 Telemetry
                Take out the power supply, remove the battery, press and hold the power button for 40 seconds. Plug in the power and try powering up.
                if that doesn't work. Let us know.
                As suggested above try it on an external monitor, likely you'll need to use a hot key combination to switch the output to either internal (lappy) external (monitor) or dual (both). It's usually the fn key ( bottom left and usually coloured blue or orange on Lenovo) and one of the function keys along the top that has a pictogram of a monitor on it.
                Cheers D
                  [QUOTE=Grumpy;1144629]The symptom if it is capacitors is difficulty in starting up, needing many attempts, but once it gets going it's ok, but it gets gradually worse until it wont start at all.[/QUOTE]
                  I'm convinced it is the motherboard and if it is then it may be cheaper to buy another lappy than fix it.:grumpy:
                    [QUOTE=woodsta888;1144632]Have you tried plugging the laptop into a monitor or TV via the VGA or DVi output from the laptop? From here you can determine if it's hardware or software related. If youget an output I'd reinstall your gfx card drivers if you have one. Depending how old your laptop is the CPU could run integrated gfx if.
                    Copy & paste the specs in nest post[/QUOTE]
                    yes it makes no difference, I think the hard drive isn't coming on as the little light dosnt come on to say it's working either
                    Trex 500l Dominator
                    Trex 450l Dominator
                    Mcpx bl
                    Pheonix sim
                    dx8
                      [QUOTE=maddog7;1144634]Take out the power supply, remove the battery, press and hold the power button for 40 seconds. Plug in the power and try powering up.
                      Cheers D[/QUOTE]
                      Yep tried that, didn't work cheers anyway
                      Trex 500l Dominator
                      Trex 450l Dominator
                      Mcpx bl
                      Pheonix sim
                      dx8
                        It eventually came on last nite so got what I needed to get done with vbar but still need to sort it as Tonite it won't work again ��
                        Trex 500l Dominator
                        Trex 450l Dominator
                        Mcpx bl
                        Pheonix sim
                        dx8
                          [QUOTE=loz;1144665]It eventually came on last nite so got what I needed to get done with vbar but still need to sort it as Tonite it won't work again [/QUOTE]
                          It might be worth opening up and just re-seat everything, unplug and plug back all the connectors etc. It could be something more major but it seems so intermittent there's at least a remote possibility something is just making a poor connection. Unfortunately laptops are usually a major pain in the rear to open up and get to everything.
                            I had a little look last nite removed ram reseated in the spare slot, wiggled some wires and connectors, still no different
                            Trex 500l Dominator
                            Trex 450l Dominator
                            Mcpx bl
                            Pheonix sim
                            dx8
                              Does it work if you go into BIOS?
