Powerful electric power
  • Powerful electric power
    [video=youtube;mAjbeDfO5Zg]http://www.youtube.com/watch?v=mAjbeDfO5Zg[/video]
    I need about 10 mins duration to get me way on a decent day...launch at 100% then back off to 2/3 for the climb. About 1500 ft agl will do. I'd have two sets of packs - I never take more than two aertotows.
    Setup is believed to be 14S from two 7S packs.
    I'm not familiar with really powerful plank setups. I'm amazed at the performance with such a small prop!
    IC versions of this mount the heavy engine near the feet and the tank on the control frame and use a much bigger prop and then need some complications to ensure clearance for the prop. This changes the balance of the harness so the pilot is much further through the control frame making it not so nice as a glider. This setup looks a lot nicer and simpler and would be a practical self launcher - but no good for flying as a powered machine from A to B due to the duration. I am only interested in using it as a self launcher.
    I'm thinking some protection ort a backup wire might be a good idea as the lipos are right next to the nylon webbing suspension strap! The harness has a carbon support plate in the back so the pilot wouldn't get burned but its more important to stop his hang strap being hot knifed in a battery/ESC malfunction!
    It does look like a very simple solution. Gotta be better then a big smelly petrol engine behind you.
    Invertix 400
    Vortex 285
    TBS Discovery Endurance
    X4 II
    Schluter Champion Longranger
    G4 E720
    G4 E720 Big AIR edition
    Goblin Urukay super slow
    Goblin 700 KSE Slow
    Goblin 700 KSE Fast
    Srimok Faifa
    Spectra G
    Synergy 766
    http://mangled-rc.com/
      Perhaps look at it the other way? How much HP or Thrust do you need? A 10HP petrol engine is a heavy beast whereas a 10HP leccy motor easily fits in a 90 heli. A ducted fan should give way more thrust than an unhoused prop.. albeit some weight penalty.. but might have a safety benefit. Personally I like the idea of having everything including batteries stuck on the end of the shaft even if that ean another weight penalty with a counterweight forwards...
      ..just thoughts
      PGK
        The balance of the harness is important. This setup has the same balance as a free flight setup. The IC engine ones balance further back which then puts the pilot further forward when you fly - meaning all the flying and trim speeds feel completely different, engine on or off.
        So motor at the back. Perhaps speed controller there too - but batteries near the front should work well.
          Thats so cool I want a go!! The guy at 2:27 looked to be going so slow I'm surprised the wing can maintain lift at the speed...
          Good, clean simple idea with the electric motor and prop/design
          Matt
          Goblin 500 Sport
          Owner of
          One E.G.S.
