1986 Honda CB350 SG Rebuild
  • 1986 Honda CB350 SG Rebuild
    Following on from P4ddys Slabside rebuild, I've been doing the same with my old honda. So this is what has happened so far.
    AS Promised. Picking up the frame this weekend from the powered coaters! Ive got an old 86 SG that the engine is knackard and was rusting away. I spent £100s on new downpipes, hoses, battery grips and stainless bolts so I thought I would completely strip it down and rebuild as best I can. Its the 1st time Ive done a full rebuild like this, but as it was a simple bike I thoought I start with it. I have had my R6 and R1 down to frame and engine, but never fully stripped.
    So this is what it will be similar too. Not identical but similar. I spent £65 on an ebay auction for engine, wheels tyres and lots of bits i needed to get it working nice and looking ok.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/450sg_zps7cf9577e.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/450sg_zps7cf9577e.jpg[/IMG][/URL]
    Let the rebuild commence.
    Here are some pics. wheels are off, and at the powder coaters.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/cd350/100_3975_zps7d23b8a0.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/cd350/100_3975_zps7d23b8a0.jpg[/IMG][/URL]
    [URL="http://s145.photobucket.com/user/stuartkeith/media/cd350/100_3974_zps579a230b.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/cd350/100_3974_zps579a230b.jpg[/IMG][/URL]
    [URL="http://s145.photobucket.com/user/stuartkeith/media/cd350/100_3973_zps24463cf7.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/cd350/100_3973_zps24463cf7.jpg[/IMG][/URL]
    http://www.clone450.sksoftware.co.uk/
    Trex 450se V2 MD500e Army
    Trex 450se V2 Clone
    Trex 500 Clone (Built just need to fix to fly)
    Blade MSR - Pocket Rocket
    Wheels off and ready. delivered today to the powder coaters!
    [URL="http://s145.photobucket.com/user/stuartkeith/media/wheels_zps22ab1e3b.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/wheels_zps22ab1e3b.jpg[/IMG][/URL]
    [URL="http://s145.photobucket.com/user/stuartkeith/media/100_4034_zps730aaf58.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/100_4034_zps730aaf58.jpg[/IMG][/URL]
    Wires tagged so can remember where they go on rebuild!
    [URL="http://s145.photobucket.com/user/stuartkeith/media/100_4029_zps949b66f5.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/100_4029_zps949b66f5.jpg[/IMG][/URL]
    off its stand and cant get the bugger back lol.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/100_4038_zps8c12adf6.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/100_4038_zps8c12adf6.jpg[/IMG][/URL]
    Just the front end left now and trying to pursude the engine to come out frame.
    Engine out of frame and bike bare now.
    Frames dropped of to the PC, forgot to take pics before it went. Had to take a dremel to the center stand bolt as it wouldn't budge.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/100_4039_zps761d5b14.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/100_4039_zps761d5b14.jpg[/IMG][/URL]
    [URL="http://s145.photobucket.com/user/stuartkeith/media/100_4040_zps9c377e12.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/100_4040_zps9c377e12.jpg[/IMG][/URL]
    Here's the wheels back from the powder coaters.
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0068_zpsebba9baa.jpg[/IMG]
    Brake discs after 1st soak in rust remover. I think one is warped will need to check on a sheet of glass.
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0063_zpsba00ec42.jpg[/IMG]
    The brake calliper after primed and 2 light coats. Need to rub down and do another couple. And some badly rusted springs cleaned and sprayed.
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0064_zpsd39af1c1.jpg[/IMG]
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0066_zpsff8fbb29.jpg[/IMG]
    And axles in soak to remove rust.
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0067_zps68188b95.jpg[/IMG]
    Here a nut that was rusty, treated in solution and then dremell with polish head and auto sol. The axels worse on some then start, if u forget and leave in too long it stops removing rust I found.
    [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0062_zpse3a1ca79.jpg[/IMG]
    Some more small bits done.
    Wheels have now had the tyres fitted.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/DSC_0076_zpsd01e888d.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0076_zpsd01e888d.jpg[/IMG][/URL]
    Some more spraying black bits.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/DSC_0084_zps6fd80d28.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0084_zps6fd80d28.jpg[/IMG][/URL]
    The swing arm cleaned, and some stop putty filling in cracked paint and cleaned rust.
    After a couple coats of primer. Need to get some more as run out now.
    [URL="http://s145.photobucket.com/user/stuartkeith/media/DSC_0082_zps353c4a46.jpg.html"][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0082_zps353c4a46.jpg[/IMG][/URL]
    Trex 450se V2 Clone
      A little bit more done over the last few days. Not much, as I have been dealing with my mums death. :(
      Just rubbed down the swing arm and sprayed the 1st coat of silver onto it. Noticed some grazing so will leave till tomorrow and sand them areas down.
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0116_zps317f27d8.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0116_zps317f27d8.jpg[/img][/URL]
      Also started on the tank as well Got the electric sander and 150grit paper out to get the stickers off and prep. Been putting some auto glym glue and tar remover over the residue to break the adhesive down.
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0108_zps6927e2fa.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0108_zps6927e2fa.jpg[/img][/URL]
      [url=http://s145.photobucket.com/user/stuartkeith/media/DSC_0109_zpsa919f2fe.jpg.html?sort=3&o=3]DSC_0109_zpsa919f2fe.jpg Photo by stuartkeith | Photobucket[/url]
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0109_zpsa919f2fe.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0109_zpsa919f2fe.jpg[/IMG][/URL]
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0111_zps76a7aaef.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0111_zps76a7aaef.jpg[/img][/URL]
      And Ive managed to straightening the rear brake rod and paint too.
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0112_zps2479c7d4.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0112_zps2479c7d4.jpg[/img][/URL]
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0113_zps67b1373c.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0113_zps67b1373c.jpg[/img]
      [/URL]
      Some pics of the rearsets before strip down.
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0105_zps07485f78.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0105_zps07485f78.jpg[/img][/URL]
      [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0106_zps9a091b92.jpg.html][img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0106_zps9a091b92.jpg[/img][/URL]
      Trex 450se V2 Clone
        Finally got my frame back, looks ok.
        [img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0141_zps345a192e.jpg[/img]
        [img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0143_zpsd3157f73.jpg[/img]
        You can see the rot here, but you won't see this.
        [img]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0144_zps53d3007e.jpg[/img]
        Trex 450se V2 Clone
          Spent a few hrs cleaning a set of carbs yesterday. Stripped apart and boiled in lemon juice and distilled water.
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221952_zps2ab36221.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221853_zps5adbbb8b.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221823_zpse278e2b8.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0167_zpsf2fef069.jpg[/IMG]
          Then in the pan.
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221926_zpsafefbb53.jpg[/IMG]
          Look a lot better after
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221745_zpsdf5f62ff.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221659_zps7df45e13.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221600_zps424f9342.jpg[/IMG]
          [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/IMG_20130712_221444_zps2da5a1dc.jpg[/IMG]
          Trex 450se V2 Clone
            OK some more bits. I have repaired the cracked seat cowl and made a new mount for the front left. I made it from a piece of broken cowl that was attached to my spare frame.
            [URL=http://s145.photobucket.com/user/stuartkeith/media/f6d70fea-2e0b-4dfe-a2e5-227690d7fd9d_zps96726f63.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/f6d70fea-2e0b-4dfe-a2e5-227690d7fd9d_zps96726f63.jpg[/IMG][/URL]
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0179_zpsfa482a28.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0179_zpsfa482a28.jpg[/IMG][/URL]
            A Spot of Etching primer over the parts I sanded down to the metal and gelcoat.
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0176_zps58ab80cc.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0176_zps58ab80cc.jpg[/IMG][/URL]
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0174_zps569541d8.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0174_zps569541d8.jpg[/IMG][/URL]
            Parts after filling dents and sanding and 2 light coats of primer.
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0180_zps90211114.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0180_zps90211114.jpg[/IMG][/URL]
            Tank and tail after more sanding and primer.
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0195_zps726e9349.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0195_zps726e9349.jpg[/IMG][/URL]
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0193_zps31feda7c.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0193_zps31feda7c.jpg[/IMG][/URL]
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0194_zpsb28c1cf4.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0194_zpsb28c1cf4.jpg[/IMG][/URL]
            on the frame.
            [URL=http://s145.photobucket.com/user/stuartkeith/media/DSC_0196_zpsaa8ca209.jpg.html][IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0196_zpsaa8ca209.jpg[/IMG][/URL]
            Trex 450se V2 Clone
              Interesting alternative to an ultrasonic bath. Not the usual kind of bike someone wishes to restore either. Looking forward to see how this all goes. I've just sold my 73 fizzy 'non runner & rusty' & parts for £1k (only owed me £120 :) ) Now i'm trying to decide which Arai I'm getting. Sorry to hear about your mum to.
                A few more pics of things I've done the last few weeks. Been busy moving house so been slow.
                Yokes cleaned off.
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0219_zps8fa6a882.jpg[/IMG]
                Sprocket carrier before being cleaned.
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0222_zpsa27e88b7.jpg[/IMG]
                And after
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0223_zps51e0b7f4.jpg[/IMG]
                Cleaned and painted
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0225_zps6beb666d.jpg[/IMG]
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0265_zps22bdf74d.jpg[/IMG]
                Exhaust bits
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0226_zpsf566df0a.jpg[/IMG]
                Fork parts together
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0266_zpsfff2f086.jpg[/IMG]
                Frame and forks
                [IMG]http://i145.photobucket.com/albums/r232/stuartkeith/DSC_0269_zps1f24bbd3.jpg[/IMG]
                Trex 450se V2 Clone
