Luckily though my Sick Canopy is totally unmarked....every cloud eh!
Inverted In Normal Mode?........Nooooooooo!
Alot depends on your setup. With elec usually hook up in hold, ID1 switch position, flick out of hold use slow ramp up. With nitro start in hold, out of hold to normal and raise manually to decent headspeed and 0 pitch then in to ID1 before lifting. Very personal choices no right or wrong. Flying around in normal mode can be useful for another headspeed or for tuning purposes.Originally posted by blahblah View PostHahah! It's a serious question though, I'm not sure why people use normal-mode with a CP heli. Bewildering hobby this. Big learning curve...
MJ
I did this for the first time on my 130X the other day. I'd done a loop and a flip before I noticed. Luckily I had plenty of height, and even if I hadn't the 130X would probably have survived.
As soon as I landed I went through all my models and set normal mode to 0% across the board on every model I have that has a soft start.Current fleet: Goblin Thunder Sport (700), Trex 700L, Logo 600, Specter 700, Henseleit TDR, V-Baaa control.
I've done ita few times now and it's always with new edge blades lol. Every time instinct tells you to try to get it back upright when in reality you would probably do less damage landing inverted lolsigpic
Funny Don, spoke to maj when I left the field and he said probably would have tried to land it inverted, hindsight eh?! Probably may have got away with it as well as it landed just off the runway in the wheat crop which is at least a foot tall now! Not enough time as I was low and as you say inverted is not the most natural position to land in.Originally posted by milly0812 View PostI've done ita few times now and it's always with new edge blades lol. Every time instinct tells you to try to get it back upright when in reality you would probably do less damage landing inverted lolGeorge
sigpic 4x EGS
If you had have come Paul you needn't have worried about getting the kids fed and in bed as you'd have been home within 15 mins!Originally posted by dentman View PostHey G , next time you call and say you going for a quick flight I'll believe you ! Perhaps I should have come along for 5 mins!!George
sigpic 4x EGS
Ive only done it once. Was with a blokes Raptor titan I was setting up for him too! A bit red faced I can tell ya!!
My helis have no pitch in normal mode all set to 0. I have to fly in idle up or they wont fly. Normal is just for spooling up the rotorSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Collector of SAB Goblins
Re: Inverted In Normal Mode?........Nooooooooo!
Dont see the need for normal mode or leaving normal at zero pitch. Have mine set for +/- full pitch. This means i can have 3 different head speed setups. Ive programmed a slider switch to disable throttle in case throttle hold is knocked to off positionGoblin T600E pro T550 T500 T450 Pro
All ModelGuard protected
OK, so who hasn't done it? It could have been worse - on the flight line at Air for instance
Me? years ago with my 250. Picked it up and wiped the dirt off.Marty
Luckily I had an audience of plane flyers who deep down were laughing there heads off.Originally posted by mole hunter View PostOK, so who hasn't done it? It could have been worse - on the flight line at Air for instance
Air flight line would have been quite bad though!! :-)George
sigpic 4x EGS
Lent my 500 a couple of years back to a mate for a flight as his helis were out of action at the time. He pulled a loop and realised that he was still in normal. Luckliy he continued through the loop and as it came round so did the headspeed.
It would have been a different story had he decided to hold it inverted though I am sure.
Bad luck mate.
I know its easy to say after the event, but could you not have just flicked the switch into idle up? (probably easier said than done when you're in a panic!)
I don't know cos iv'e never done it (YET!)
I like having the 3 flight modes and always take off and land in normal, but my flying is somewhat sedate!
What i did once do though, was land my 450 in idle up by hitting TH and doing a mini auto, then switched TH off and as i didn't have soft start set on my 'cheapo ESC' the heli spooled up full throttle and did a funky chicken beating itself up on the tarmac!
Dan.
TREX 550X - Beastx HD Pro
GOBLIN 570 - V-Bar Neo Pro
Taranis X9D Plus
neXt Sim
AccruRc Sim
Proud wearer of 3 X EGS
