Originally posted by FuturaSE
View Post
Once again: If gravity is much higher then air density (assuming the same earthly proportions) would be much higher so more lift and more drag on the rotors. I suspect you would need to reduce pitch or keep it the same; certainly need more powerful motors or reduced rpm. In any event the model will fly slower through the soup..
