Mcpx bl. How's it doing?
    Probably Nick, i just need something small for indoor clubs and inverted backwards training.
    Goblin 500 SK540 jive 100lv
    HD 500 SK540 jive 80 lv
    Oxy 3 SK540 minijazz20
      It flies great for what it is dude
        A flying turd. Lol.
          Re: Mcpx bl. How's it doing?
          Ha Ha Ha put the big boots on Graham . I can see this being stomped to death quicktime
          Rob .
            Ok. I have it here and early indications are ok. The blades are level at mid stick so no messing with pitch trav adj needed,yet
            Notice they still put grommets on the swash as per all the other poo helis they make. Why can't they just make a swash that doesn't have slop ?
            Are these grommets even fit for purpose or do they need swapping for thicker ones like the old one or 130 poo?
            What sort of flight times are you getting? Manual says 3-4 mins.
              Huh,it's not dead yet??
              4 mins for me
                Lol. Not yet. Just had a little play in the living room, flips nice and tight. Haven't rolled it yet. Taking it to work tomorrow for a better test.
                Ive set the expo at 30 as I think I read somewhere 40 was too much also reduced pitch trav to 90 90
                does that sound about right for it? Anything else, like trav for ail or elev?
                  Im using 5% expo and 95% pitch.
                    Must feel like a huge sponge at 30 then. I'll have a play tomorrow and see where it ends up.
                    Thanks.
                    • #25
                      Is there a parallel charge cable available to charge the jst style plugged nano techs? Single charging these will not do
                      • #26
                        Parallel Charge Cable - JST x 6
                        http://www.fast-lad.co.uk/store/quan...ml?language=en
                        • #27
                          Thanks Nick.
                          • #28
                            If you want to ballance charge get a para board from budd
                            • #29
                              Already got one Nick. It's just the lead I need thanks.
                              • #30
                                What's the para board from Budd?
                                Stu
                                Avant ultimate, YS91srs, Hatori, vBar, JR HV, Edge
                                T700, YS91srs, Hatori, vBar, Torque 9088/9188, Edge
                                Logo 700 Xxtreme, Scorpion, Helijive, HC3-sX, BLS 451/251, Edge
                                Logo 600sx, Pyro, Helijive, vBar, BLS 451/251, Edge
                                Logo 500se, KDE, Jive 110lv, HC3-sX, BLS 451/251, Edge
                                T550, Pyro/Jive 110lv, vBar, BLS 451/251, Edge
                                T500, Pyro/Jive 80hv, HC3sx, I2 head, Edge
