bought and sold from last year?
  • #31
    Started with 700n velo 50 600n 250se
    Got now 700n 700eand 550e oh and bl mcpx.
    Sent from my iPhone using Internet.
    Gaui x7 lush
    Gobbalin 500
    ALL ON SPEKKY GEAR
    Blade 130x2
    nano
    • #32
      I can't honestly remember what I started the year with. Srimok E defo but not sure what else. Will look
      Brought this year:
      Logo 500
      Logo 600 3d
      Logo 600 se
      Aurora E
      Trex 500 ESP
      Trex 250 se
      Trex 550
      Fusion 50
      Vibe SG E12
      Protos 500
      Sold this year:
      Logo 500
      Logo 600 3d
      Logo 600 se
      Aurora E
      Trex 500 ESP
      Trex 250 se
      Trex 550
      Fusion 50
      Vibe SG E12
      Protos 500
      I only got the Srimok E, Synergy E7 and the Trex 500efl pro left.
      • #33
        Originally posted by Dedcalm View Post
        Not seen an F1 since about 2001! I flew a mates F1 46 back then as I was considering once myself...
        the bell 222 i sold had a f1-60 inside
        Hirobo Turbulence D3
        1/4 scale Vario Bell 47 G3
        1/3 scale Vario R22
        2012 LHC Scale Cup Judge
        • #34
          i have only being doing it for month
          i started off with a mcx2
          then the awsome mcpx
          now my 450 sport
          and my biggest heli the 550e v2 :P
          now i think its time for a nitro
          Tbs discovery quad
          Align 700L Dominator
          Gaui x3
          mikado logo 480 Xxtreme
          • #35
            I seem to have trouble letting go of the helis so the line for 2011 is:
            Graupner Helimax 60 with Huges 500 body (requires Restoring)
            Kyosho Concept EP (1 with jet ranger body the other with Hughes 500, both require restoring)
            Kyosho Concept 60 (Requires Restoring)
            Tsk Mystar 46 Requires restoring
            TSK Mystar 60 Restored (awaiting test flight)
            TSK Mystar 60 fitted with YS 90 four stroke Restored (just requires setting up)
            Xcell Fury tempest with YS91 (needs a rebuild)
            Trex 450 pro
            Trex 500 flybarless
            Trex 600 CF on 8s
            Trex 600 pro Nitro with OS55
            Trex 700N
            Trex 700n covered to electric with Heli Chris frames FBL
            Srimok 90N (1 with YS 91 & the other with OS91)
            Added to the collection this year
            Volt 700 electric FBL
            Srimok FIFA FBL
            Awaiting the srimok 600 for 2012
            Kasama Srimok (OS91HZ), Kasama Srimok (YS91SR), Srimok FIFA, Trex 700N, Trex 600N, Trex 600E, Trex 500 FBL, Xcell Tempest 91, TSK Mystar 61, Volt 700E FBL,
            • #36
              Started the year with a 450pro and a 600LE. Just sold the 600 airframe to make way for a velocity 50 N2 and am looking to sell the 450 as I don't fly it as much as the 50 size
              Del
              Climb-Out
              3D Scotland
              Proud owner of 2 EGS
              • #37
                Started year with
                velo 50
                fusion 50
                700 pro
                450 pro
                mcpx
                ended with
                700 pro
                450 pro
                600 v2
                fusion 50 (smashed to bits 24/12/11)
                mcpx
                Martin
                Aka RCSlopesurfer
                • #38
                  Damn, that's a bit of a drag man.
                  This year was the year for mechanical failures for me.
                  In reverse order my crashes were;
                  Blitz Avro - engine cut in a turn upwind, tried to auto but had to turn downwind
                  and had too much forward speed, ground not smooth enough, damage was a
                  nice new set of blades :-( boom, TT, crown gear, feathering shaft.
                  Century Predator SE gasser - main rotor shaft somehow slipped downwards during the
                  inverted portion of an aileron roll, blade tip chopped into the boom. Managed to
                  auto it and finally get it flipped back upright before reaching the ground. I still
                  have not ordered the parts (boom, TT, skids, main and feathering shafts, etc.)
                  Ely.Q Ultimate - tailrotor pulley came loose during a stall turn, too low to stop
                  it spinning completely. Damage was blades, boom, skids, feathering shaft, some links, etc.
                  Hirobo Sceadu evo 50, had two incidents earlier in the year - main gear
                  stripped badly in flight but didn't crash then the anti-rotation pin came
                  out of the swash (the outer swash on that heli is plastic). Various
                  damage, blades, skids, lost Spektrum sattellite, etc.
                  Raptor 50 had two incidents, both minor. Aileron servo failed causing a
                  crash (boom, blades, skids etc.) then a link came off the swash causing
                  a bent feathering shaft and main shaft but no crash.
                  So, an expensive year in that regard, lots of broken blades and various
                  parts.
                  • #39
                    a fair amount of damage there!
                    I think I have only gone in twice this year from memory, a record.
                    Got a lot of making up to do in 2012!
                    x 3
                    • #40
                      Cant complain trillian it was my 1st one for over a year.
                      It was a failure of some discription as the thing was hovering fine with probably to high a head speed & I think the blade grip
                      link came a drift. I will convert back to the flybarred head & get it back in the air.
                      Martin
                      Aka RCSlopesurfer
                      • #41
                        Yeah, I did a lot of flying this year so I guess it is somewhat in perportion. Some of the mechanical
                        failures were not things that were likely to be detected in pre-flight checks and were just
                        co-incidence that several of those things happened within a few month span but it did worry
                        me a bit. Only one crash was caused by 'dumb thumbs' and that was with my 500 but
                        the damage was minimal and it was flying again very soon. (I did also crash the 450s
                        but that wasn't dumb thumbs it was just me being silly too low to the ground).
                        Maybe the answer is ultimately to only have a few helis flying at any one time and
                        in addition to the regular pre and post flight checks just do a total rebuild now and then
                        to catch those unseen potential failures. This is where you appreciate the helis that are
                        easy to work on and spot problems and is one reason I love the Robbe Futura and Milli.
                        • #42
                          Start of year
                          450 pro,600le and 700le all with flybars.
                          in between
                          Velo 90.
                          Now have
                          550fbl,fusion 50fbl and 600efl pro.
                          • #43
                            Originally posted by KnifeEdge View Post
                            I have lost track, I think:
                            Srimok 90E - Sold
                            Trex 700N -Sold
                            Rave ENV - Sold
                            TDR - Sold
                            Logo Xxtreme - coming in. 2012
                            There was a 550 as well but best forgotten RIP...
                            Sold my 600...
                            Still got my Raptor 90s and got a G4 one of the 1st....wanting one of these heads Fbl 90 head.jpgthe Raptor 90s are going to be around for bit longer yet...
                            Sold my 600...
                            • #44
                              Lol. Yes forgot the 550 RIP!
                              James
                              SEMAS Flying Club
                              • #45
                                1x trex 600n sold
                                2xavant auroras sold
                                1x trex 700 sold
                                1x logo 600se sold
                                1x n5 sold
                                1x msh Protos keeping
                                2x logo 3ds keeping
                                1x tdr not finished yet ;-)
                                somethings that fly??
