Sorted! The Manager kindly popped round this evening and got it fixed. Essentially a radio set-up issue on the gyro screen in terms of inhibiting the mix for the idle-ups rather than allowing it, plus setting the end points for channel 5 for gyro gain in both modes/sides of the switch, then bringing the rudder channel end points back up to 100%.
Have moved the servo horn hole inwards one, so all I need to do now is do some test hovers in normal mode to find the tail blade hover pitch setting, tighten it all up, then the job's a good un.
Thanks again to The Manager
I owe you one.
Once I shift my cold I'll be out there getting it dialled in.
Cheers - Rob
I owe you one. Once I shift my cold I'll be out there getting it dialled in.
Cheers - Rob
