what plug
    Too fast and you risk damage to the engine if fuel starts to burn as the piston is still coming up, too slow and not all the fuel will burn and the engine may not idle reliably, so it's a balance of those two extremes.
    The fuel needs to start burning as the piston is travelling up so that it reaches its maximum intensity as the piston just goes over TDC and then driven down with the fuel producing its maximum pressure.
    The temperature of the plug is a very technical area. One that I have not had much dealing with. Just because one plug works for person A doesn't mean it will work for person B. All factors have to be taken into account: The engine's compression ratio; the amount of nitro in the fuel; the type of exhaust; the density of the air; the ratio of fuel to air mixture and maybe some others.
    What I do know though is if the selected plug is too hot you will almost certainly damage the engine due to the firing of the fuel not being clean and controlled.
    Member of Mk Heli Club
      Originally posted by machasm View Post
      Also bear in mind that Higher nitro contents usually require a cooler plug. Conversly lower nitro content require hotter plugs.
      i shall be using 20% optifuel in both helis the raptor has the os 32 and the 600 has the os 50 will the same plug suit both.
      Trex 550e dfc :-)
      t-rex 450s x2 /Raptor 50
      kyosho spree small plank
      bogey combat plank x2 woop
      http://www.cuffleymfc.co.uk
        I'm currently using MT 20% fuel and now have OS No8's in all my helis - 1 x OS37, 2 x OS50 and 1 x YS91 engines. Works fine.
        JR Vibe Fifty fb (YS56)
          Enya 4 in my o.s carbed redline engine on 20% opti fuel and its running sweet not much power difference between 30% either. the plugs seem to last a lot longer for me than than the o.s8.
          Sponsored By
          Goblin 500-V bar T-rex700N with FLYBAR.
          http://www.lindensmfc.co.uk/
            Yeah, I was trying to keep my explanation as simple and concise as possible, the point being you don't want that max intensity to be reached too soon
              Ian, if you're running 20% nitro or more you may want to look at the enya #4 rather than the 3.
              Its a bit cooler than the #3 which will counter the advance in combustion that higher nitro causes so you may find that with higher nitro contents it runs better and develops more power.
              Current kit
              Evo 50
              T-rex 500FG night setup.
              T-rex 700N pro
              T-rex 450 pro
              10CP
              Frankenstarter (dynatron)
                Found this tech article
                http://www.iroquois.free-online.co.uk/gloplug.htm
                Although a little old I think the theory is still the same.
                Ade.
                  my bad just checked im on enya 4 thanks
                  Sponsored By
                    thanks once again for all the input .now where do you all get your plugs?
                    Trex 550e dfc :-)
                    • #25
                      From a model shop.
                      • #26
                        Originally posted by Steve View Post
                        From a model shop.
                        always a smart one lol but which one(shop i mean)
                        Trex 550e dfc :-)
