Did YOU fly today??
  • Originally posted by NiceBlades View Post
    I managed to "pop" one of the cells on the lipo! landed safely and no fire just a bit of smoke!
    That's an unusual failure. I've never seen an undamaged LiPo burst while in flight before, usually they only do that after a crash.
    Was it in good condition before flying?
    • Maybe a sharp cable tie end or something it could be pushed into?
      Spektrum IX12
      Blade Inductrix
      T-Rex 150X
      T-Rex 450L, Heli Option Turn-buckles, carbon push rod, 6s, Stock Electrics, Giant Power Lipos
      Goblin 380 Kyle Stacy, 360mm, 6s, AR7210BX, Align 430m/525m @ 6.0v, Castle Talon 90, Scorpion 3020-1000, Optipower 2700 30c
      Goblin 570 Carbon Red, Stretched to 600mm, Blackline 3D Blades, 12s, BD 3SX, Align 800/850 HV servos @ 8.0v Castle 120 Phoenix Edge HV, Scorpion, Thunderpower G8s
      T-Rex 800e Pro DFC, Hobbywing 200A, 760x Head, BeastX
      • One lipo cell did have a tendency to be a little more drained than the rest after a flight, but would always charge to 4.20v. I think it puffed during flight, as the pinion made a mark in the top cell, then just burst, I do have a pic on my phone I'll have a go at putting it n here, Ian.
        [/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
        • Could it be thet the pinion/shaft rubbed a hole in the battery causing the cell to puff and burst? I know the clearance between bottom of the pinion and shaft and the top of the battery is very tight on some Goblins with larger batteries and if they arent held down real tight there can be contact.
          In any case it's good news that there was no fire, that would have been nasty!
          • Grumpy, no as the top cell wasn't the one that popped, damage to the top cell by the pinion was probably post "pop". Im really glad there was no fire!
            • Since it's stupidly windy today I spent my lunchtime siming instead
              At least it's cheaper to crash that inverted than the real ones lol
              Lynx Heli Team Pilot
              • Got my first sustained inverted flying today. Never tried it before. Of course used the nano. Crashed quite a bit with no damage. Was really enjoyable. Almost like learning to hover again. Well I suppose it was!
                Then coming into land. Gust hit it and pushed it into the metal legs of our trampoline. Result. Snapped swash arm. Balls. Won't be replacing it with another Alu one. Plastic will do fine for me.
                Spektrum IX12
                Blade Inductrix
                T-Rex 150X
                  4 flights tonight with the Raptors, Nice evening but a bit chillie
                  Regards Adrian
                  I AM SPARTAN V4 + Spirit---TT--RAPTOR-E820 x 2-E755-E700--SYNERGY-E7SE--ALIGN-600PRO
                  --... ...-- neXt
                  A few bits and bobs & a few electric gizmos to stir the air.
                  • Nice 2 on the 550 and 250 but the torque tube snapped on my 450L in the middle of a wall which resulted in it spinning out of control... Only a small crash: Blades,Skids,Feathering Shaft,Thrust Bearings,Lynx DFC arm and obviously the torque tube!FullSizeRender.jpg
                    GAUI Factory Pilot
                    Fast Lad Team Pilot
                    DryFluid
                    • Had 2 flights with the Titan x50e- only on 6s but enough for sport aero's.. 12s setup is definitely on the horizon though !..
                      Sab Goblin 570
                      Sab Goblin 500
                      500E Pro dfc
                      450 Pro dfc
                      Blade 300X
                      DX9
                      • Originally posted by Hamish View Post
                        Nice 2 on the 550 and 250 but the torque tube snapped on my 450L in the middle of a wall which resulted in it spinning out of control... Only a small crash: Blades,Skids,Feathering Shaft,Thrust Bearings,Lynx DFC arm and obviously the torque tube![ATTACH=CONFIG]82481[/ATTACH]
                        i wonder if that scoring happened just because of the snap, how many bearings do you use on it?
                        Spektrum IX12
                        Blade Inductrix
                        T-Rex 150X
                          Its looks to me like bearing was possibly glued in wonky,and ground down the tube?
                          • Trex 700N RMJ,msh brain
                          • Goblin 700 black thunder sport,vbar Neo
                          • Trex 700L Dfc,vbar Night Flyer
                          • Trex 700x,Vbar Neo
                          • Goblin 570,msh brain
                          • Goblin 380 kse,msh brain
                          • ​NeXt sim and DX9 and Vcontrol
                          • Nick I think that it had started to develop a bend in the torque tube from a previous crash, and the centrifugal force had thrown it onto the side of the boom. I crashed it a few months ago and i think the torque tube was ALMOST straight. I will probably put a second bearing when I rebuild.
                            GAUI Factory Pilot
                            Fast Lad Team Pilot
                            DryFluid
                            • i crashed my t rex 450 trying to learn flying towards me then turning right always get my inputs wrong but put two batterys through the brand new never flown by me t rex 500 and took it home undamaged.
                              • Four flights with a 450 and two with a 550 this morning
                                Phone with time lapse, some 2 pics/sec, took the pic.
                                This 450 is a HK 450 PRO with a ZYX-s, with some 1500 flights on it.
                                Regards,
                                Bo
                                HK, Align, Mikado and SAB. 450, 380 500, 550, 600, 600SE & 700.
