Reflex vs Phoenix
    Originally posted by TimmyB View Post
    Cheers for voting lads, see you soon for an online session!!
    If your lucky..
      Nice!! isn't it great when things come together and work out the way they should.................the sim's some years ago when i was last flying them were very one dimentional......what i've seen of the phoenix is that its very realistic in flight.
      T3ds Gy240 S3153 with trex500 skids and trex500 fin set plus now with hybridized canopy and Mini Titan canopy body post set P# PV0816.........Now owned by MoJo have fun
        Just bought the Phoenix today calibrated it in (suposidly!!) and the swash is set to 90de's......well the fixed wing stunt plain flys ok well but when i try and fly any heli there is just enough pitch present to lift off about 6' at best (scratch head) crashes are very real though......lol what am i doing wrong ha!.
          What Tx are you using?
          Is it set to heli mode on the model memory you are using for the sim?
          Is the swash set to 90°?
          Is it calibrated correctly?
          | 3D Championship
            1/ dx6i
            2/ yes
            3/ yes
            4/ hopefully!! although its questionable.
            I've just had another go and changed the model from a B400 to the Trex600 and its flying as it should do with a great locked in tail etc.........what setting in throttle / pitch curve do i need to dial in to go fly in 3d mode please............thanks in advance.
              Phoenix every time!
              I have run Phoenix on my lap top at my clubs indoor evening. We ran Reflex side by side on an identical laptop. Needless to say everyone perfered mine for phisics and realism.
                Originally posted by Mojogoes View Post
                1/ dx6i
                2/ yes
                3/ yes
                I've found some settings and after loading them its now my tx neutral is at centre stick with positive and negative at high and low positions respectively.........some of the scale models seem a little less resposive on the tail plus the gyro setting and stability when you go from say a 90 size to the Bo135 seems to be a bit numb.
