Distraction. Whoops!!!
    Originally posted by Peteski View Post
    LOL! Reminds me of one of my old man's favourite sayings:- "Now look what you've made me do!!"
    Lol. I used to say that to my kids. In this particular case I just muttered 'You Tw@t' to my self at which point he wandered off and found someone else to talk to. I don't even know who he was.
    Graham
    Titan X50E Bavarian Demon 3SX
    Trex 500L Bavarian Demon 3SX
    Trex 450SE Flybar
    Futaba 14SG
      Originally posted by Grumpy View Post
      [INDENT]
      Done that too many times to count. Usually the cause is being sloppy when you connect the balance plug, entering it into the socket 'wonky' and touching the wrong pins. Unless the batteries were at very different states of charge simply connecting the balance leads first wouldn't do it.
      One of my boards has more solder bridges than it does copper trace It is an easy repair, just take some strands of copper wire and solder over the gap.. job done.
      All done. Jobs a goodun. Just ordered some 6s balance extension leads. Might make it easier in the future. It does get a bit crowded around those boards.
      Graham
      Trex 450SE Flybar
      Futaba 14SG
        It maybe a good idea to put a quick blow fuse in that track to prevent a burn out again, or if someone is into electronics some form of ressetable relay. Just a thought.
          Yup. Been there done that to a perfectly good parallel charging board. Now I only fused ones.
          |SAB Goblin 770 Competition Carbon|SAB Goblin 570 Carbon|SAB Goblin 380|All Kontronik|All Mikado vbar 6.0.6| Mikado vbar Control TX & RX|
            There are 14 traces coming from the balance connector pins... Not much point fusing only one of them, even if it was possible to do it.
            If it's something that worries you polyfused boards are available. Personally after making the same mistake several times I'm just more careful now and fingers crossed it now been a good while since I burned a trace.
              must be a common mistake I did exactly the same last week, will try the mend thought .
              cheers Tigeral
              aka Hull City - Phoenix rotors nottingham
              Logo 600 SX V2 Neo & ZMR quad
              Synergy 700SE Neo
              Main and only Sponsor of Tom Inglis
              Align 600e dfc vortex N1, Scorpion Sky strider Quad
              Avant Mostro 700E
