Just had a thought after what you just said to check, can I adjust sub trim equally until I get equal angles high and low stick in conjunction with swash mix?
Or, could I use travel adjust equally on the three servos to control how many degrees I get either side?
By the way, swash is level, wash out arms are level, as are the mixing arms.
Both blades are within 0.3 degrees of pitch to each other and the total runout with the fly bar locked is 0.4 degrees around the whole 360 degrees.
and a platinum star
