Originally posted by cycled
View Post
Trex 450L Dominator - any good?
Costs as much to build too, based on most of the builds I see. It's just daft comparing a G380 with a Trex 450L.. The former typically costs about £750 RTF, the later around £370 (half the price). If you were going to compare it to a Trex heli then compare it to the 550L as it's about the same price.Last edited by Grumpy; 27-12-2015, 09:00 AM.Goblin Kraken, SoXos Strike 7, XLPower Specter, Goblin Black Thunder T, Goblin 700 Speed, Goblin 770 Comp Carbon, Trex 700X, Kasama Dune, Henseleit TDR
If you want something to throw about that doesn't cost too much to crash (inevitable when learning 3D) then a 450 is probably the way to go. I've been through a few myself and finally settles on a Compass Warp 360. It's got a very low parts count (doesn't even have a feathering shaft!!) and flies brilliantly.
If you want something with a bit more poke and size then perhaps look at a 500 size. Still not too bad on crash costs, the align 500L looks superb, I personally fly an MSH Protos 500 which I find to be brilliant too. Againi its got a very low parts count and in over 600 flights its only needed a set of dampers and a main shaft (only as it went rusty after flying on a beach!!)
A 500 will at the very least equal a G380 but cost far less to build and cost less to crash. At the end of the day any of the current crop of 450-500 sized machines will do what you need, don't discount a 3s powered 450 either! More power than you'd think as my 3s powered TT mini Titan v2 proves!Last edited by gazmk2; 27-12-2015, 09:14 AM.MSH Protos Max V2. Vbar Neo, Cyclone 715, zeal, talon 120
Futaba 14sg
If I was going to do a 450 on a budget, I'd get a Gaui X3 for sure. You only ever hear good things about it and it seems cheap to crash - especially compared to a larger 500 size heli. The MSH Mini-Protos is another option too and very well priced combos.
Having said that I just bought a Goblin 380 KSE, but I'm under no illusion that it will cost more to run than either of the above.SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
Spektrum DX8 - for everything
neXt sim - the sim I started out with
Get yourself a gaui x3 basic kit, Lynx 380 stretch kit,hobbywing platinum 50a esc, I've get a gaui scorpion 6s motor , then you just need lipos and a fbl system, but if your still fresh I'd forget about a bailout, with a 450 there's more chance you'll save it than hit the switch.
i can't slate the 450l, I quite like it, but for a 450 3d trainer that you expect to push,metal doesn't crash or cost anything like plastic parts.
