Originally posted by BladeStriker
View Post
SWRCH Grassroots Christmas competition
To late Mark your allready entered lol . Not sure if Ross paid your entry fee yet though mate . RobRob .
Yeah, it's not like you fly it so may aswell!sigpic
Goblin 500 SK540 jive 100lv
HD 500 SK540 jive 80 lv
Oxy 3 SK540 minijazz20
Sponsored by
Align-Trex.co.uk
Optifuel/optipower
MKS servotech
Ha! - I just realised - I was reading the wrong list! GRASSROOTS list! I did think "Reversing Pirouetting Vertical Diamond" sounded a bit advanced!Originally posted by moonmanflyer View Post
Just so everyone is clear on what's involved. You choose any five of the above manoeuvres. The higher the k factor the higher your score could beManoeuvre Number Manoeuvre Name K Factor Manoeuvre Description 1 Hovering T 1 A hovering T shall be flown with a 3 second pause at each point 2 Hovering M 1 A hovering M shall be prescribed with skids at eye level. 3 second hover at each point 3 Staged Hover 5, 10, 15ft 1 The model will hover at 3 heights, 5, 10 and 15ft with a 3 second pause at each point. 4 Side On Hover 1 The model shall hover for 10 seconds with steady control of drift. 5 Level Pass both directions 1 A forward flying pass shall be flown with the same speed and height in boht directions 6 Large Circle 1.5 A large (50ft) forward walking speed circle shall be performed with skids at eye level 7 Hovering Vertical Top Hat 1.5 The model shall perform a top hat manoeuvre with a 3 second pause at each hover point. To be performed slowly with a 3 second pause at each point. 8 180 Stall Turn 1.5 Performed to the left or right at comfortable height with the turn away from the flightline. 9 Nose In Hover 1.5 Perform a nose in hover with skids at eye level for 10 seconds. 10 Loop 1.5 A loop performed at medium speed ith a consistent entry and exit height. 11 50ft Auto 2 This autorotation be performed in any format in a safe manner with a controlled landing 12 Travelling Aileron Roll 2 Axial travelling roll and controlled speed. 13 Vertical Triangle 2 3 second pause at each hovering point. No piros in this manoeuvre. 14 Reverse Side on Hover 2 10 second pause to each side with a 180deg piro to change direction. 15 540 deg stall turn 2 Performed to the left or right at comfortable height with a turn and half away from the flightline. 16 Figure of 8 2.5 The model shall prescribe a figure of 8 pattern flown slowly in hover conditions. 17 Remote Tail in Circle 2.5 Flown under hover conditions, with the model prescribing a circle,with the tail pointing constantly to a centre point. 18 45 degree Descent 2.5 Steady descent at consistent rate to a hover in front of the pilot 19 Tick Tock 2.5 To be completed side on or head on. 3 repetitions 20 Double stall turn 2.5 Left and right hand sides with turn away from the flightline. 21 3 stationary elevator flips 3 Completed at a safe height with consistent height control and flip about the mainshaft of the aircraft. 22 Remote nose in circle 3 Flown under hover conditions, with the model prescribing a circle,with the nose pointing constantly to a centre point. 23 Inverted level flypast 3 Pass of 50ft flown forwards or backwards at controlled height and speed 24 Mini Rainbow 3 Controlled height approx 20ft wide with smooth changeovers. 2 each side. 25 Reverse Backward Circles 3 Flown slowly in hover with consistent height control. 26 Travelling double roll 3.5 Consistent height and speed 27 Travelling backwards Loop 3.5 Entry and exit to be at same height. 28 Knife edge Piro 3.5 Comfortable height, piro start and stop to be crisp. Entry and exit at same height. 29 Vertical triangle with 180 piro 3.5 Pause for 3 seconds at each stop point. Controlled 180deg Piro at top 30 Nose down or sideways Tick Tocks 3.5 Controlled Height, 3 rerepetitions
