Hello everyone,
any advice on this would be greatly appreciated !
I have a Tarot 450 pro and I'm just learning to hover. Can hold it steady and now trying to do some tail-in figure 8's. However I have noticed that if I give a sharp throttle increase command on the tx then the tail blows out counter clockwise. The gyro quickly corrects this, but I want to eradicate it, if that's possible.
i know that it is happening due to a sharp spike increase in the torque generated by the main rotor accelerating sharply and the tail can't keep up(it is a torque tube). I have tried playing around with the gain getting and have been able to reduce the problem slightly but I now believe I have the optimum gain setting as if I increase any further I start to get a twitchy tail.
i have read that this problem can happen if your head speed is too low. I am still on basic throttle curves and i was using:
0%, 40%, 65%, 75%, 75%
I was only hovering when I gave the command and was below hover speed, so to try and solve the issue I changed my throttle curve to:
0%, 55%, 65%, 75%, 75%
but the problem is still there, but it is slightly better. Is this normal if you do this whilst operating at the these head speeds ? Will the issue go away when I progress to higher head speeds and throttle curves ?
is there anything else I can do ? The only thing I can think of is my pinion. The kit came with a 13t but the motor itself came with a 12t. The 13t was a poor fit for the motor so I am using the 12t, do I need to put a 13t on there ?
Many thanks in advance !!
james.
james.
