Hi chaps I've got this issue with phoenix, it only happens on two flying fields the Lakeside and Sandbar, however before my dell reinstall earlier I'd downloaded more scenes and a few of them done the same.
I've taken a few images to show you what happens, when I try and change the scene to say the sandbar this is what I get.
And there it sticks, until you change a screen, then I get this colour behind the black where it should only be black.
Then if I'm lucky and i manage to get onto the Sandbar for example this is what happens
The other fields play fine even of I do have the strange colours behind the Phoenix screen.
The Lappy is a Dell Inspiron 1520, also the bleeding Dell media wizard also makes some suprise appearances as well. but that's another thing.
The graphics is the Mobile Intel(R) 965 Express Chipset Family
DAC Type Internal
Adapter String Mobile Intel(R) GMA X3100
Its running on Vista Basic, with 1GB DDR2 RAM
Phoenix is running V1.05c.
In Vista when you remove a program unlike XP, windows takes care of the removal as where in XP when you go into add/remove programs Phoenis self uninstalls its self.
Now earlier today I uninstall phoenix using the "Uninstall A Program" section in control panel and after a while all was deleted so I thought.
Bear in mind that before I deleted Phoenix I'd been flying the trex 500.
So after removing Phoenix I installed it back, only to find the trex 500 in the heli lists and of course I got the message that this machone cant run on the version the disk arrived in which was 4.soomething?
So I'd have thought that heli would have been deleted along with the program, I tried this another time and the same thing happened.
So I had to do a factory reset of the software as I thought have a fresh start, so after installing AOL and other programs I put the Phoenix disk in loaded it, then downloaded the updates and bang back to square one with these two playing scenes.
This doesn't happen on the desktop, so how I see it, Vista doesnt do a complete clean uninstall of Phoenix as fragments like the trex 500 was still there after a new instal, on my desktop as the new update made the screen jump around and not smooth like before that new update I uninstalled the program in Add/Remove Programs, then put it back on and all was fine.
However with my Dell Laptop and Vista this doesn't seem the case, I don't know if the Laptop has a fault as when you pick it up the CD draw makes the sound like you've just placed a disk in and its read it for a second, and before the Dell Factory reinstall it kept spitting on the Phoenix disc when I tried to instal it then after the third attempt it finally started to read it.
Plus just before the Factory instal the bloody draw wouldn't open at all, which now after the lappy has been reset to how it arrived from the box that now works OK.
Any ideas chaps, I'm pulling my hair out in frustration here, as I say only two fields crash when trying to open them, and with the ones that do manage to fly on I get those colourful lines in the background.
(Now with 3GX)
