Hello, newbie to heli flying but having fun. Picoo z and gyrotor got be interested now onto lama v4 with eye on belt cp for future.
Has anyone else upgraded the lama v4 to the metal collet set , central holder and main shaft, down central holder and swashplate?
I was hoping it would improve the lama v4, but I think the upgrades have made it to heavy, and now heli will not have hover at all!
All it wanted to do was take a nose dive straight into the back lawn.
So I have put the original plastic ones back in.
Is this upgrade worth it? has anyone had any success at all with this upgrade? i.e upgrading to the esky metal parts?
Any info appreciated
thanks
dave
thanks
dave
Update on alloy parts, one of the things i have noticed with the inner shaft and alloy top is while it locks fly bar in place it is easy to bend it when you have a crash, also when you maneuver fast it does have a tendency to whack the blades, another word of warning is the 4 screws that hold the rotor blades onto the frame's have a nasty tendency to work loose, as i found out last night when the two bottom blades went for there own flight. Luckily never done any damage. So i would suggest locktight on screws, at moment i have plastic lower rotor holder back on, personally i think the swash plate is the only thing that is worth changing on the upgrade that does make it that bit more responsive. As i said on earlier post i noticed no real lack of performance or less flying time, but as said the cracks are showing with them and well the jury is still out. If anything it will get you used to trimming the rotors up.
