Hi All,
I'm glad to say that m'little Esky Lama V3 and I are getting along very well now. Since re-routing the ariel there have been no more glitches at all and upgrading the inner shaft to an alloy topped model that secures the stabilzer bar has also improved handling. Repairs have been cheap and after shortening both control rods half a turn, she is nicely trimmed. Thanks to the forum for all those tips.
I'm flying at least 2 batteries a day in the fairly limited space of the front room. Tail in I can hold a nice hover, even when less than an inch off the ground, and I can also land on 2 CD cases placed together on the floor.
Where I am having a lot of trouble is getting used to any other orientation! Once the heli turns more than about 45 degrees in either direction, my control goes almost completely. I know it is a case of practice, practice, practice, but wondered if there are any hints or tips you could pass on to make the process easier? How did you go about learning nose in flying?
Any comments would be most welcome.
Mark
Mark
I hear that, I think I was lucky with it, as most of my early flights were nose in, so quickly learned that when rudder came into it, right was clockwise, left wasn't, then once I bought my Blade I only had to learn sliding the wrong way. But side on is a killer still.
