Hi, Just fitted a brand new os37. Started fine, cut out after approx 30 seconds. Tried to restart, but starter could not turn the engine over. Took the engine out removed glow plug turned the engine over by hand using the clutch. Put back into heli and started straight away, ran for approximately 30 minutes to help bed in piston. all was good. Stopped engine and waited until this evening to do some more running in. But the starter wont turn the engine over again and i cant turn it by hand. i will remove the plug again and see if i can turn by hand. It seems as if there is far to much compression. Has anyone got any ideas. I can take it back to the shop if i have to but would rather sort it myself if possible.
Thanks, Darren
Thanks, Darren
