nitro problems
  • nitro problems
    I'm having fun!! with my SC 32 engine as in it runs lovely at the idle but bogs downs and cuts out as soon as I open the throttle.
    I,m using Irvine formula 10 fuel and an OS no 8 glow plug, I have tried various needle settings on both main and idle. This makes no difference, I changed glow plug to Enya No3 this improved it on the ground as I could get to Half stick with no problems. So off I went to get some hovering practice and the engine obviously got very scared and didn't want to run correctly and went back to it's old tricks!!!! I tried new fuel and same again.
    It could be all manner of things.
    If you set your needles back to factory setting, does that help?...
    How old is your fuel line? have you checked your fuel line, including in the tank for leaks?
    What model is it in, how old is the engine? has it ever run properly?
    If it was me, I'd pop it out of the heli, put a fixed wing prop on it, mount it in my engine stand, and then get it roughly in tune that way, knowing that I had power across the whole throttle range.... If it wasnt working properly like this, id strip the carb and give it a good clean, make sure the needles were good e.t.c.
    Logo 600 3D --- Vortex Vx1n
    JR Forza 700 --- Vortex Vx1e
    And the proud wearer of one
      nitro problems
      Ditto above really - best way to set it up is with a prop and bolted down on the bench.
        nitro problems
        As Jimmy says, it could be a number of things. I had the same problem with my raptor 50 the engine would cut when i got past half stick, I too put an enya no. 3 plug in which works a lot better than the no.8 Another thing I found was that one of the head bolts on the engine had come loose causing an air leak!
        Dan.
        TREX 550X - Beastx HD Pro
        GOBLIN 570 - V-Bar Neo Pro
        Taranis X9D Plus
        neXt Sim
        AccruRc Sim
        Proud wearer of 3 X EGS
          In response to jimmy it's in a century hawk and the fuel line and tank are leak free, I would return needles to factory setting if I knew what they are!!! If anyone knows then I would be grateful !!
            I ' diitto' the run it on the bench lol.
            I had the same problems yrs ago with an Irvine 40 in a mini boy. Turned out it was a piston/ liner fault. Take it out, put a prop on it, pref one thats on the biggish size to put load on the engine. And set it up using that.
            At least then y'll know if it's an engine fault or a set up flt. It'll be a lot quicker in the long run rather than struggling with big blades spinning next to yr head lol.
              nitro problems
              Make sure you put the right size prop on it - not just any old prop. Need to make sure it is adequately loaded.
                You can bring it down if you like. I have a century hawk (actually have both the 30 and the 50).
                One of the potentials for problems with the fueling here is that the fuel lines can get caught and 'pinholed' on the metal pipe in the fuel bung, also the copper of those pipes can corrode and either block your carb if you havent used a filter but also again cause pinholing or a bigger air leak. I had this once and had exactly the symptoms you describe, but it may be something else.
                If you can do the trip down to Winchester/Southampton for an hours tinkling, im more than happy to see if I can set you right.
                  i had a brand new 1 of these engines a few years ago, and sorry to say this but it was an absolute pig to tune, never really got it to in the end so got an os 37, all my troubles went away.
                  Gaui x7 lush
                  Gobbalin 500
                  ALL ON SPEKKY GEAR
                  Blade 130x2
                  nano
                    I never give up on engines - I think we've got 3 or 4 SC engines now, all running great! I admit, OS engines are the easiest to get running, but I've even got some unbranded engines that I've repaired and got running - in fact I'm just finishing off a vintage nitro buggy with a supposedly Leo engine in (although it's unlabelled so cannot be sure) that I've got running from many years left in storage
                      +1 on that! Never got it to run. New OS37 and I never touched the settings from out of the box.
                      There is a massive build quality difference between SC and OS.
                      Happy Landings.
                      David
                      Raptor 50. OS50
                      Mcpx
                      Blade 130x
                      Goblin 500
                        nitro problems
                        Have to agree here. I've just put an OS37 in the Gaui NX4, practically starts first time every time. Out of all nitro's defiantly the easiest.
                          Thanks for all your comments and I would like to take you up on the offer of your time jimmy. Unfortunately I'm busy till next weekend but please let me know how you're fixed and hopefully we can sort something out cheers
                            This weekend is our new clubs opening weekend, and next weekend im working nights, so thats out...
                            After that should be fine though
