how do you get this thing back on????? the belt i mean?
belt cp belt!
Andy:
Sorry sence of humor took over....
They are a bit of a pain.. Split the tail gearbox remove the tail slip the belt over the front pully thread it down the tail wit a bit of string and check the direction.... Then add quatar a turn onto the tail shaft when rebuilding the tail gearbox... Check the rotation both leading edge's go the same way.... then pull the tail backwards and tighten the front pinch bolts. Check the belt tension it should go to about the middle just behind the front pully end then fully tighten the pinch bolts
Steve
Steve...
Outrage RC Field Rep
