Msr battery.
  • Msr battery.
    Hi
    Could someone help me with + and - on my msr battery please? I need to charge my battery's using a proper lipo charger as the 4aa charger I have is eating through several aa's a week. I just need to know which side is + and which side is - so I don't destroy the battery! I'm looking from this angle.
    Have you got a charge lead/harness for charging your lipos? You will need some sort of connector to connect to your charger, this will only allow your lipo to plug in the correct way like you would when connecting it to your msr.
    a parallel charge lead looks like this :-
      Re: Msr battery.
      I have a couple of USB charge leads from a perkins twister heli which I will be butchering for now until I get round to buying a proper charge harness. The leads have the correct femail plug to accept the msr battery.
      Where is the harness you've put a pic of from?
      thanks
        Parallel (6x) JST-PHR-2 Charge Cable MCPX AC-PJPHRC
        You don't need to know which pins are which. Just get a connector and plug it in. Check with a meter. If you don't have a meter now is a good time to get one. Check that parallel charge leads work by trying each position( socket) on its own in case there's a wiring error.
        Blade 130-X, MSR, MSRX
        Phoenix Sim
