just got my belt cp form china about 30 mins ago.few issiues which im no happy about right enough.1.i asked for a white heli and got a yellow one.2.the cf pin that holds the canopy on is broken and canopy is split.(ok no big deal) if that isnt bad enough and it dosent comes with any free main blades or tail blade or even training kit! what a con.emailed him and said i aint happy.heres waiting.got the battery on charge and going to take it from there.
finnally here!
what up bummer, where did you get it from andy.
look at this vid and check his other vids out. i know its a king but it is vry similar to the belt cp - [ame]http://www.youtube.com/watch?v=Dh30iHwx4GY[/ame]
take note of that 3d switch - make sure you have yours in the right postition.
watch all his vids on setting up the king2
matty - any probs im in the chatroom
matty
Spektrum DX7s
DJI F450 naza/gps Trex 500
sorry to here about the damage - hes been a good seller to me - he will/should sort out your problems - damage + spare blades and traing gear. the tube for the antenna is at the bottem of the box
matty
Spektrum DX7s
all trims in the middle apart from the throttle trim that should be down as well as the throttle stick. make sure that 3d switch is pushed away from you. put heli on a level surface. turn on tx and then plug the lipo in. dont move or knock the heli while the gyro is setting. it should be flashing. when it stops flashing your ready to go. might take upto 15 secs to set. then your ready to go.
i have training legs if you want me to send them to you. you should really have them because the heli will easilly tip over and smash itself to bits. would only take a couple of days to get to you. better to be safe than sorry. dont rush things. be cafefull because its not a toy and can cause some serious damage and injury.
pm me your address if you want the training legs.
if i was you id wait for them.
goodluck - matty
matty
Spektrum DX7s
have you flown a heli before? you better be very carefull - you dont want to crash it
matty
Spektrum DX7s
delfin - the guy you bought it from is in a different time zone so you'll have to wait untill he gets outa bed and on his pc. think he's in canada
matty
Spektrum DX7s
how you getting on with your belt now joe? sorted all you problems?Originally posted by pxr5 View Postmy cf rod on the canopy was also broke. also had bent main shaft, bent feathering shaft and bent tal shaft. came from china but diferent dealer to yours.
i only need -
1 x NEW! Aluminum CNC Swashplate Mount Set1 x NEW! Aluminum CNC Receiver Soleplate1 x NEW! Aluminum CNC The Bearing Holder of Drive Belt Wheel1 x NEW! Aluminum CNC Tail Boom Hold Set1 x NEW! Aluminum CNC Motor Mount Set1 x NEW! Aluminum CNC Left & Right Rudder Angel1 x NEW! Aluminum CNC Front Rear Rudder Controller1 x NEW! Aluminum CNC Bearing Set on Main Shaft
then my heli will be full carbon and cnc. then im going to put it in an airwolf.
http://www.esky-heli.com/esky-belt-c...o-pr-1767.html
matty
Spektrum DX7s
ive just posted them legs for you. there is clips to fit them to the skids(they fit but not properly) ive put you a few cable ties in aswell so might be better to just use the ties. try and get the center and the training gear directly under the main shaft. hope you manage to get every thing sorted.
regards - matty
matty
Spektrum DX7s
