Hi everyone, Today I was hovering my 450 Sport V2 in my garden while timing to work out my flight times now I have a Torque tube conversion kit fitted on it I got to 6 mins when I noticed signs of the power decreasing so I landed, but my garden is not perfectly level, so the tail rotor touched the mud and stopped which stripped the front torque tube gears, That made me think, "how can I stop the tail rotor hitting the ground on unlevel ground"? I got an old metal coat hanger and cut it the right length to go from the top of the tail stabilizer "if thats what you call it" all the way to just off the floor and attached it to the tail stabilizer now the rotors stay about 3cm off the floor will hopefully stop the gear stripping in the future if not I have a set of 4 front gears on order
u can hardly see the coat hanger wire. I will practice using the hold switch for landing, what percentage throttle do u recommend for a throttle hold? I have throttle cut set to 5% which stops the rotors completely.
