The gyro isn't really a gyro. That is is doesn't use a gyro to do anything. It's an anguler rate sensor with some electronics to make it look as though it knows where it should be pointing. An angular rate sensor just measures how fast the tail is turning. Just turn, nothing to do with movement. The sensors are not very accurate and give different outputs when you first switch on. To make this work they measure the output for a few seconds after switch on and assume that this means zero turn. That's why you must keep it still at switch on. This is called calibration which sounds better than bodge the sensor. After this, if the heli is in hold mode it measures the turn that happens and how long the turn lasted. The electronics then works out how many degrees the heli has turned. It then sends the opposite turn to the servo until the rate of turn has lasted long enough to get you back to where you started from.
When the heli is in the air this works ok, but when on the ground it is not so good as the heli doesn't turn very well on the ground, or when being carried. This builds up errors. If you switch into rate mode just before take off this will reset the gyro and it will not turn to the side. Or put the heli in it's final position before switching on.
