Why is my aileron control controlling my throttle
    No wires have been unplugged ir moved
      right firstly. press and hold the scroller whilst turning on the dx8. then find the system setup menu. click the scroller third line down should say "mode 2" if its not change it to mode 2. then see what you have.(although it does now seem you have indeed got a throttle /aileron mix set in.)
        All the more reason to start from scratch I'd say.
        SAB
        Trex 500 FBL /
        Beast X
        Futaba 8FG
        Proud Owner of 2 EGS Awards
          Could it not just be that you have one of the servos reversed by accident, and whats happening is when you are going throttle up, the reversed servo is going down (Because its reversed) rather than up, and this is making it seem like aileron control?
          The swash moves up and down when you move the throttle dont it, one of the pitch or aileron servos is reversed then youll get aileron type movement rather than pitch.
          TT Raptor G4 + Vbar
            I was in mode 2. I am going to go through my F mode set up and switch select again.
            If I do a model reset do I have to bind again.
            Once again thanks to everyone for their advice and help.
            Adam
              I looked in Servo set up and the controls are all on the wrong sticks how do I put this right?
