Have put it back together following crash which took out both blades and also removed some teeth from the outer main shaft gear. In the meantime a heatsink has been fitted.
Carefully put it all back together and tested the motors before fitting new blades. Noticed that the swash plate was tilted to left but everything seemed to be working (servos etc) OK.
On pre-flight testing of the yaw/rudder control, i.e. with motors running move the yaw control left and then right to check that one blade and then the other slows down whilst the other one speeds up. Noticed that with the control to the right the lower blade spun more slowly than the top one, by quite a margin. This difference was confirmed by the strong tendency to yaw to the left on the cusp of lift-off with the training gear fitted.
On top of that it was also moving towards eight o'clock.
Have not changed any adjustments so settings should be the same and therefore the swash plate should be level, so don't understand why this has changed, unless this is a by-product of the crash. It seems the obvious thing to do to remedy this is to change the length of the left side servo rod. However, before I do this I thought it best to get some comments from the forum please.
Thanks in advance for any help on 1) remedying the motor speed differential affecting yaw and 2) the swash plate angle.
