When holding the heli and putting throttle up a tad to check all is working ok i noticed that when i apply elev / aileron/pitch the swash stays where it was after i centre the sticks back. The servos remain where they are left ..........confused phil....... ps if i close the throttle they return ok ?
mcpx trouble
It's normal. The mcpx is a flybarless heli and as such, the servos are actually controlled by the onboard controller. When you apply a control input, the controller expects the heli to move. When it doesn't (because you're holding it), the controller continues to apply the input. When you close the throttle, the controller knows that nothing will happen so it just moves the servos directly according to your input.
Hope that makes sense.
TTom
