Ok got my new FlyCamOne v2 the other day and straight off the bat had a few problems.
Firstly they will not charge off pure Mini USB socket chargers (like the ones that come with a Blackberry) NOR will they charge off normal USB to Mini USB cables either. I founf the only way to get a charge was to use a USB to Mini USB cable that came with my Cannon Camera and that has a big lump in the cable which I assume is some sort of filter. anyway so I finally have got it to charge and hold a charge. Problem 1 over.
Secondly ... Don't believe the Website !!!!
This camera WILL NOT work with anything bigger than 2GB. I tried 4 and 8GB and even a new hybrid 6GB SD card and they all have a problem being recognised and the 4Gb is intermittantly recognised. So 2GB is the max on an SD card. Problem two sorted.
Next the lens and aperture is very very small and so is extremely sensitive to lighting conditions. The frame rate might claim to be 25fps (on the website...robotbirds claim 30fps) However it 'looks' like a lot less. Frame rate is very jerky and poor. Looks more like 10fps. The screen often 'washes-out' with light conditions changing so the picture quality isn't very good at all.
However you get what you pay for sooooooo for £40 I'd say it 'just' about makes it worth playing with as an entry level into video's for modellers. It is amazingly light but on the whole pretty unremarkable.
