I use it on cyclic at 20%(JR9X Tx), you can go one of two ways with it. You can either increase the sensitivity or reduce of any channel just about so that the stick will either be very responsive to stick inputs or the otherway.
My cyclic is less sensitive, this helps to give me a near rock solid hover when inverted and low.
I've been reducing the expo over the last few months and I will look to reduce it to 15% in the next month.
Ok, I'll try it out as soon as the weather gets a little better. Sometimes it's hard to keep a solid hover, but the sticks on my transmitter are very responsive.
Thanks Stuart.
