More advice please
  • More advice please
    Hi very new to flying recently purchased the Phoenix software to practice and also got a trex 450 however I need to buy a receiver and some batteries for it can any
    one recommend which batteries to use and were to buy ?
    Also iv bought a dx6i and need a receiver for it ? Any recommendations ?
    Been advised to get a ar6200 receiver to start ? Any help greatly received
    a dx6i will do ok for both pheonix and your trex 450 the ar6200 is ok too
    Raptor 50 v2
    Raptor 50 titan se
    Raptor X50n to go in sea king fuz
    Raptor 90
    dsx9 mk2
    600 size Sea king being built
    Bo-105 in red bull colours waitng to be built
      AR6200 is fine, however a Ar6100 might be an easier fit (and cheaper). Or even a 6ch Orange RX clone, cheaper still.
      If you're not in a hurry then Turnigy batteries (the blue ones) 2200mAh 3S 25C (or higher) from HobbyKing. If you're in a hurry you'll also find them on ebay, or Loong Maxx Tipples or Gens Ace packs from Giant Shark, all are good.
      Trex 450 Pro
      450SEV2
      mCPX
      Recycloquad (tm)
      Edge 540 Foamy
      AXN Floater Jet
      MDC F-14 Tomcat
      Depron BAE Hawk
      www.thedailymice.com
        Recommended Lipos for a 450 are 11.1v, 3s, 2250mah
        Personally I would go for these.
        http://www.modelhelicopters.co.uk/li...50mah-40c.html
          Thanks for the quick reply whats best for chargers ??
            Ouch, £30 a pack? Get 2 of these! http://www.giantshark.co.uk/gens-2200-lipo-battery-p-406466.html
            W
            hat's your budget for a charger?
            Trex 450 Pro
            450SEV2
            mCPX
            Recycloquad (tm)
            Edge 540 Foamy
            AXN Floater Jet
            MDC F-14 Tomcat
            Depron BAE Hawk
              Overlander from Kings Lynn Models. £20 ish and good batteries. Not had a problem with mine and you can get them with the appropriate connecter (Deans or EC3) already soldered on.
              B6AC charger from same, has built in power supply. Depends what you want really but I find it serves me well. About £45.
              AR6115 receiver is nice, real small, too.
              Vikki.
                Really depends on how you are looking to progress in the hobby.
                Something like this will get you started
                http://www.modelhelicopters.co.uk/ta...i-charger.html
                The only problem is this hobby really has a habit of sucking you in fast. Before you know it you maybe looking at buying bigger helis that have bigger Lipo's, so may have to upgrade your charger too.
                  GT Power A-6-10 from giantshark, about £50 I think, or cheaper from HK.
                  Needs a power supply, converted PC or server PSU works well. The A-6-10 is a 200W charger so will serve well all the way to 5000mAh 6S packs
                  Trex 450 Pro
                  450SEV2
                  mCPX
                  Recycloquad (tm)
                  Edge 540 Foamy
                  AXN Floater Jet
                  MDC F-14 Tomcat
                  Depron BAE Hawk
                    Thanks again just one more thing been looking at chargers what are balance chargers ?
                      B6AC is a balance charger/discharger as are most of them. Essential for multicell lipos.
                        A balance charger is essential, it ensures that all cells in the pack are evenly charged - balanced. Over time the individual cell voltages can get out of sync, this is potentially bad for the battery. In the worst case 1 or more cells can get overcharged which is dangerous.
                        You can tell a balance charger, proper ones charge the pack via the main discharge leads and have a separate socket or board for the balance plug to connect to.
                        Trex 450 Pro
                        450SEV2
                        mCPX
                        Recycloquad (tm)
                        Edge 540 Foamy
                        AXN Floater Jet
                        MDC F-14 Tomcat
                        Depron BAE Hawk
                          A balance charger will ensure all the cells in a battery are fully charged and wont over charge the battery, its essential for safety really.
                          Joe
                          Invertix 400
                          Vortex 285
                          TBS Discovery Endurance
                          X4 II
                          Schluter Champion Longranger
                          G4 E720
                          G4 E720 Big AIR edition
                          Goblin Urukay super slow
                          Goblin 700 KSE Slow
                          Goblin 700 KSE Fast
                          Srimok Faifa
                          Spectra G
                          Synergy 766
                          http://mangled-rc.com/
                            hi guys could you have a look at this and see what you think for a balance charger
                            Turnigy Accucel 6 lipo charger LiPo/LiFe NiMH Nicad UK | eBayhanks
                              Hi
                              i have a Trex450pro here in UK and one in Thailand and i use the AR6100 RX on one and a AR6115e on the other, they are fine.
                              For charging you might want to look at the Maxpro X3 Quint multiple pack charger, they charge through the balance leads, you can charge 5x packs in approx one hour or so, the chargers need a 13.8V power supply, maybe the Ripmax Pro peak 13.8V Dual output.
                              Lipos i use are Turnigy 2200mah 35C packs. ps Turnigy X5 3cell 5 port charger is another make of the same charger. hope this helps...
                              Brain Goblin 380. Brain Goblin 500 sport. Spirit Trex550e DFC. (BeastX Trex450Pro, BeastX Trex550e DFC... in Thailand)
                              Brain Oxy 2, Nano CP X BL.
                              neXt-Heli, DX9. DX6 G2. PL8 + Coolice 2400W PSU.
