batteries
  • batteries
    hi i just want to know a bit more on wot battery can be used with wot.
    say ive got a 380 brushed stock walkera motor and a 35a esc could i use 2200mah 3cell 20c with that? or wots the highest i can go? same again with a 3500kv brushless motor and esc wots the highest and lowest i could get for this set up sorry if it sounds like a stupid question but i cant get to grips with this 20c 11.4 volts 35amps etc am confused
    any help would be great thanks
    __________________________________________________
    trex se v2
    hs-65mg servos
    gy401
    beam E4
    scorpion 2221-6 motor
    55a esc
    hs--65hb servos
    gy401
    dx7
    Hi,
    I take it you have a walkera heli with the stock motor and 35amp Esc.
    In order to get the most out of the motor and Esc combo you want your batteries to be able to deliver the max draw, in your case 35amps. To calculate this is simple, Take the c rating, in your example above 20 and times it by the capacity of the battery in your example 2200 and then divide by 1000
    20x2200/1000 = 44
    Walkera's tend to come with 20 amp ESc's though so anything over 20 is fine.
    Ie 10c 2200mah, 12c 1800mah, 15c 1800mah etc etc
    Be carefull to check the size of the batteries too, as you will probably find that the 20c 2200mah are too big to fit inside your heli.
    Hope this helps
    Grant
      cheers mate so i take it the lower the --C the less poweful the motor will be
      trex se v2
      hs-65mg servos
      gy401
      beam E4
      55a esc
      hs--65hb servos
      gy401
      dx7
        It is a combination of c & capacity. Which heli have you got???
        I had the Walkera 60 and extended the battery cage in height by inserting ali rods of about 8mm between the base plate and frames, this allowed me to use the 15c & 18c 2200mah batts.
        Grant
          ive got a 60# with stock motor currently waitin on a brushed motor and esc to arrive it doesnt feel like the motor is powerful enough it came with a 1250 3cell 10c battery
          trex se v2
          hs-65mg servos
          gy401
          beam E4
          55a esc
          hs--65hb servos
          gy401
          dx7
