need some help with hyperion eos0615 duo3 charger
  • need some help with hyperion eos0615 duo3 charger
    can any one tell me how to charge two lipo at the same time , can only get one side working at a time
    You need to sync charge identical packs or are you wanting to charge 2 different packs?
      no just identical packs
        Sync charge then,put in the details of the pack,press and start till it days charge,press again and i think it flashes then up or down to sync charge,will charge as one big 12s with 2 x 6s packs for example.
        Think thats right,been a few weeks since i did one.
          ok thank you will try it
            You only need to put details in one side and the charger will automatically do the other side
              thank you for your help all sorted thanks
                Theres a button that changes the channel.
                Its marked CH & changes which side your using to charge, ie port one or port two.
                Its quite simple when you get the hang of it.
                I've got myself a P late now as a replacement for my duo
                Martin
                Aka RCSlopesurfer
                  Do you mean a PL8 Martin PMSL , or am i missing something ?????????? Rob
                  Rob .
                    Yup a PL8 Rob but stevo calls it a Plate.
                    Martin
                    Aka RCSlopesurfer
