ok so i took my blade 120 sr out side i gave her some air and right away she started to spin out of controll blades one direction and the rest the other direction i checked the links on the swash plates there all ok any body no the reason its doin that plz need help
more blade 120 sr problem
yes the tail rotor blade is spinning like it should the battery is good ive only had it 3 weeks now with only maybe not even 5 hrs flight time i just dont no wat goin on it just started doing this todayOriginally posted by sd330ml View Posthave you checked tail motor + blades, trim on tx and is batt goodstuart
