blade 120sr problem
  • blade 120sr problem
    i have the blade 120sr im learning on with the rtf radieo. the probley is as soon as i give her throttle she likes to drift to the back right side all the time no matter how much i tweak her anybody knows the reason y or can give me any advise on wat to do thank u.
    I have never flown one. How far off the ground are you? Were are you trying to fly? Ie. In house, back yard, grass, concrete. Video would be good for a laugh
    Sent from my GT-I9100 using Tapatalk 2
    Raptor 50 v2, trex 600n fbl, trex 550 v2 3gx, trex 450 3gx v2, mini-titan v1, mcpx v1, WoT4 foamE, Gootch 450, mcpx bl.
      Check the swash links are always in place. Re-centre your trims as well. Don't forget the long beep means that your in the centre of trim travel. I spent a couple of days thinking the Heli wouldn't trim up properly when in reality it was just that I was trimming full left - centre and not ever trimming right.
      Pitch links sounds the most likely here though...
      TT Raptor G4 + Vbar
