ok i have a toy rc helicopter i have that i use indoors when i cant practice my 120 sr. its a syma s107 when i fully charge it i can pull the throddle all the way up but it dont get high of the floor anyone no wat could be the problem. but it looks like its going full power
spooning up problem
Is the main gear pushed right up the shaft if it isn't tight you dont get enough pitch for it to lift too high?- TREX 600esp - TREX 600e - TREX 450 Sport - Eflite Blade MCPX - Eflite Blade MSR -
- DX7SE - DX9ii - Pheonix -
* Loads of Gear & Still No Idea *
Have you got another battery to see if it still does itToday's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Tighten the little screw that holds the head onto the main shaft.
I also have one of these that i bought for my daughter and had the same trouble, i changed the battery which didnt work and a google search led me to tighten the main head screw which i had already checked and thought was tight but they need to be done up as tight as possible or the head slips on the shaft.Last edited by animal47; 12-04-2012, 02:22 PM.
I had a problem with spooning up, too. I guess I should at least have found out her name first.Neil H: Certified
compatible.
You beat me to it,Originally posted by unwind-protect View PostI had a problem with spooning up, too. I guess I should at least have found out her name first.
Martyn
Very true, I wasn't sure what I was going to find when opening up the threadOriginally posted by LaurenceGough View PostThis title was asking for problems to be honest!!
Pictures or a video would help if you can (of the heli! lol)
Martyn
