Twister 3D
  • Twister 3D
    Apart from the usual "should have bought a T-Rex" has any one who had or has a Twister 3D solved the seemingly Tail Heavy problem.
    I'm using a 2100 Revo lipo but having to put nearly 2oz of lead in the front to get it to balance c of g on the flybars.
    Question 2 re-the use of 6mm solid carbon rod for the main shaft whats the best grease/oil to lube it I thought carbon was very abrasive why did people go this route is it a better shaft or just a lot cheaper option ?
    Hi mate when i had mine i moved my battery to as far forward as i could and used Velcro straps to hold it tight and it was spot on for me, but i found that i had 3 different makes of lipo so the CofG was never spot on with each battery.
    Mine was a steal shaft not carbon so thats a change for the kit
    MK HELI CLUB WEB SITE
      PAck the battery foward by about half inch with a bit of foam or poly it balances perfectly (metal tail tube) and you dont need any lead
      Steve
      Steve...
      Outrage RC Field Rep
