Spektrum from a Blade
  • Spektrum from a Blade
    This could be a dumb ass question, so apologies................
    can the 2.4 radio gear from a blade cx be used again in another heli? or is it purely made for the CX2.?
    (I'm from the fixed wing world where all tx & Rx are moved from model to model)
    sorry again if its a real stupid question. Thats a newbie for you!
    Blade mCX
    Hirobo Quark SRB
    Walkera 4#3 Brushless (SOLD)
    Phoenix Sim
    I'm guessing it can because if you look at the 4 in 1 box (Don't know about the new 3 in 1 ) only 2 of the connectors out of a possible 6 are used.
    Mind you....the 4 in 1 is exactly that...i.e. it incorporates a gyro etc. and is not HH so you'd need to recognise that this Gyro is very limited in it's response and behaviour..... thinking it through further the little box of tricks then applies it's tail drift and YAW corrections or inputs to the throttle output channels. (It's co-acial so it won't apply changes and inputs to a tail servo but to the motors...)
    So in short...you could pull it out....but what would you use it for ?
    You'd need to experiment a lot I think to map it's behavior.
    *** CX2 with extra Bling *** STATUS
    *** HoneyBee Belt CP *** RETIRED
    *** Phoenix Sim ***
    *** T-Rex 600e 1st REAL Heli :- GY611 + S9256 + 3*S9451, DX7+AR6200, Revolution 4800 20C 6S, Radix 600 *** STATUS
      The Blade tx is set up as a plank I believe (no seperate pitch channel I guess) as I had to set up a Spektrum DX7 to plane mode to fly a blade.
      I'm not sure that the blade tx can be used to fly a heli but have never tried it??
      Cheers, Lee.
      Proud recipient of an EGS
        I think the new version blade has a 3in1 with which you can use your own hh gyro
          LOL.... fitting a GY611 on a CX2.... silly thing wouldn't get off the deck
          *** Phoenix Sim ***
