I'm preparing to take my BMFA A test for helicopters. I would like some pointers to which sections of the BMFA handbook I should spend most time on learning?Could members chime in with some example question etc... That they were asked when they took the test. If there are any examiners who see this post I would love to get some direction on which sections to concentrate my efforts. I still have quite a bit of time to prepare.
BMFA A test questions
If you read the bit in the BMFA handbook about the test, it tells you which sections you need to revise. There was a web site that had a random quiz generator on it but I'm afraid I can't track it down.
In my test, it was a right grilling, covering just about everything. But I think you just really have to demonstrate that you've actually read the thing (have heard of some that just had a few easy questions). Doesn't hurt to know your sweets from your smarts
Just found the RCHA post with the test generator, unfortunately it's a broken link now. http://www.rcheliaddict.co.uk/main-discussions/11642-bmfa-test-practice.html
If you go here you can take the fixed wing test, which has similar questions: British Model Flying Association - Midland Area
+1 but then we had the same examiner I believeOriginally posted by Detritus View PostIn my test, it was a right grilling, covering just about everything. But I think you just really have to demonstrate that you've actually read the thing (have heard of some that just had a few easy questions). Doesn't hurt to know your sweets from your smarts
Lynx Heli Team Pilot
click on the test in Detritus's post for the midland area
do the fixed wing tests but read up on the heli sections in the bmfa hand book
the heli test hasn't worked for a whileHirobo Turbulence D3
1/4 scale Vario Bell 47 G3
1/3 scale Vario R22
2012 LHC Scale Cup Judge
1/3 scale Vario R22
Learn and understand - Air navigation orders, sweets, smart, pre-flight check & general safety
Plus anything else in the handbook - Read all of it twice over the week before the test - you'll be fine.
Raptor 30V1 Maverick Head
OctoCopter
Futaba 14SG
read it every luch break at workOriginally posted by Mslater View PostLearn and understand - Air navigation orders, sweets, smart, pre-flight check & general safety
you will get sick of keep reading it over and over but you will remember it
and what is the minimum nose radius of a model?
when you can answer it we'll know you've read the hand bookHirobo Turbulence D3
1/3 scale Vario R22
7.5mm
But it really only applies to Gliders and then specifically to competition classes and the FAI definition of a model aircraft.Last edited by Mslater; 08-03-2012, 12:31 AM.
OctoCopter
Futaba 14SG
the question wasn't aimed at youOriginally posted by Mslater View Post7.5mm
and yes very correct its in the glider sectionHirobo Turbulence D3
1/3 scale Vario R22
I know, thought it was a bit unfair but you are right, read the whole thing anyway.Originally posted by electricsceadu View Postthe question wasn't aimed at you
OctoCopter
Futaba 14SG
Don't forget it's not just the BMFA handbook, but also your club/field rules. Layout, no fly areas etc etc.
+1 for a grilling on the questions, I finally twigged that something was amiss when I got rocket trajectory questions!!
I guess thats what happens when your the examiners caller!Synergy whore
N7
N5
N9 FBH, FBL
N9 homebrew FBL - retired for parts
E7 SPEEEEEEEEED
E5
E5 ss
it is a question i herd at the end of a B testOriginally posted by Mslater View PostI know, thought it was a bit unfair but you are right, read the whole thing anyway.
the examiner was after those who were listening in on the questions to read the handbook
and it worksHirobo Turbulence D3
1/3 scale Vario R22
