Batteries and Charging
  • Batteries and Charging
    Okay so I have my Accucel 6 and charging harness and 6 nano-tech batteries for MCPX.
    Can I just run this by you folk to make sure I understand the basics of lipo charging on a proper charger...
    These are 300mah 1s batteries, that means .3a each, right? So if I charge on the Accucel 6 at 1.8a (1c?) it takes all 6 an hour to charge?
    The next jump is the .6a (2c?) (3.6a for 6) and should take 30 minutes to charge? So if I go in the middle to preserve the battery life I'm looking approx 45 min for all 6 batteries, at 2.4a 3.7v?
    I've been reading everything I can online and can't seem to find concise write ups, so just want to double check with those in the know.
    Sounds right to me but I don't know the charger. I assume you set the charger for all cells.
    Raptor 30V1 Maverick Head
    OctoCopter
    Futaba 14SG
      Are they in series or parallel.
      Sent from my iPhone using Internet.
      Gaui x7 lush
      Gobbalin 500
      ALL ON SPEKKY GEAR
      Blade 130x2
      nano
        Ive not charged loads in one goe but sound about right on times but the 1c bit you are correct But it will be less thsn an hour becouse you didnt compleatly kill them did you;-)
        Sent from my GT-I9000 using Tapatalk
          Charging in parallel, setting the charger for 1s. As long as they don't all blow up and are charged eventually, I'm happy :-)
